Results 1 to 5 of 5
Thread: VT struggles/backfiring on lpg at revs, what could my problem be?
    '97 VT Exec
    Feb 2010
    Croydon Hills, Melbourne
    Question VT struggles/backfiring on lpg at revs, what could my problem be?
    Hey all.
    I have a vt with dual fuel(exec, auto). When i run it on gas it runs fine and i dont really see much of a performance drop, but when i rev up to about 2300-2600 rpm it always sort of bumps/struggles/backfires but when its not in that rpm range its fine?
    Just wondering if anyone can suggest what the problem would be? could it be the computer or something?
    it runs fine on petrol, and anywhere out of that rev range on gas.
    thanks for any help!
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Plugs , leads and air filter , any of these or a combination of them will cause ur problem , an yes it will run fine on fuel but not on gas if any or all are stuffed . coil pack could also cause a drama
    start with thy cheapest an work ur way up if u dont know how to test these items
    At 43 a wealth of info , but still heaps to learn
    '97 VT Exec
    Feb 2010
    I recently put a lukey air filter in but its always done it so i can rule that out.
    Plugs and leads could be a good start to tell the mechanic next service. really got no idea how to test any of that lol
    cheers!
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    In that specific rev range on gas it won't be the computer (that is I'm assuming you have a carby styled air mixer gas system, rather than direct injection which is ECU controlled).
    Check your DFI module, that causes backfiring, though if the problem is rev range specific and fuel (LPG) specific, then the problem will most likely lie with the gas system.
    First step is to check leads, coils, DFI, sparks etc...but I'd take it to a LPG workshop to be sure. LPG is prone to problems when all is not perfect, and hard to fix.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    '97 VT Exec
    Feb 2010
    Yeah dad (previous owner) told me that the lpg mechanic has no idea where the problem lies but said something about the ecu. I was also told it is a direct injection system so i guess the mechanic could be correct, i just find it weird that it always struggles at the exact rev mark. Whats a DFI also?
    It's not the worst problem in the world though. sometimes i just drive it on petrol coz i would like to get above 2.5k smoothly
  1. LPG problem - wont start and backfiring - help needed
    By VRcommondoor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2010, 02:14 PM
  2. Vs V6 struggles for power!
    By RATTLEHEAD88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 12:04 PM
  3. vibration/shudder problem @ high revs VZ Calais
    By goodday in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-04-2009, 11:46 AM
  4. my continued struggles
    By tr3nt in forum The Pub
    Last Post: 30-01-2006, 01:35 AM
  5. Farty backfiring problem
    By Panelvan1975 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2005, 11:54 PM
Tags for this Thread
