Results 1 to 8 of 8
Thread: VT Commodore coolant leak
    VR
    Jun 2010
    Default VT Commodore coolant leak
    Hello Gentlemen,
    My GF's 1999 VT was overheating a lot, so i bled the coolant system and replaced the coolant etc. Hasnt overheated since, but when we park, go away for a while and come back after weve been driving, coolant is dripping from under both front seats. its 2 individual drips, one under the drivers, and one under the passengers (outside of course )
    Any idea what it might be?
    Kind Regards,
    Frag
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Are you sure it is coolant and not plain water from the air conditioning drain pipe?
    MY RIDE
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Open the bonnet and look on the drivers side and you will see some metal of the car's body that is probably acting as a tray for the previous coolant to rest in, at the end of that is ahole, that is probably just excess coolant dripping through that hole (the metal might be the chassy of the car I'm not overly sure). If you have a look in the engine bay you'll see it storing the coolant.
    VR
    Jun 2010
    Accent thats what i thought first up mate, but the second time it happened it was green. You guys think it could just be overflow? because it took about a liter of water into the radiator after that second leak.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Coolant leaking from the area that you described could be a leaking heater core. Is it dripping from above the front of the transmission?
    MY RIDE
    VR
    Jun 2010
    sorry accent i dont actually know where the transmission is located... i presume just in front of where the gearshift is... if the tap was turned to cold it wouldnt leak right? because last time it leaked we turned the dial to the middle of the white as it was a bit cold...
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Fragmaggot View Post
    If the drip is coming from an area about in line with the front of the front doors but towards the middle of the car then it is probably coming from the aircon drain hose and a leaking heater core is the only way coolant can get there. If the heater tap is closed it still might leak because I don't think those taps are completely water tight.
    MY RIDE
    VR
    Jun 2010
    hmm okay thanks for your advice accent. oh, and nice ride btw
LinkBacks (?)
  1. 07-01-2012, 01:09 PM
  2. 14-12-2011, 12:02 PM
  3. 10-12-2011, 09:16 AM
  4. 04-08-2011, 04:02 PM
  5. 28-06-2011, 07:27 PM
  6. 25-05-2011, 08:54 PM
  7. 04-04-2011, 02:46 PM
  8. 19-03-2011, 05:45 PM
  9. 20-02-2011, 09:33 PM
  10. 19-01-2011, 09:49 AM
  11. 18-01-2011, 09:02 PM
  12. 08-01-2011, 07:01 PM
  1. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  2. Coolant Leak
    By inais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2009, 11:19 AM
  3. Big coolant leak
    By Rithumanbloos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2009, 10:28 AM
  4. coolant leak
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2007, 03:30 PM
  5. VN V6 Coolant Leak
    By robert_buntine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2004, 07:37 PM
