Results 1 to 17 of 17
Thread: Vt s2 v6 ( flat spot/ power loss )
    vt wagon
    Jan 2011
    sydney
    Default Vt s2 v6 ( flat spot/ power loss )
    I have a prob that 2 mechs and a auto elect couldn't figure out.The prob is a flat spot/power loss from idle to 2400rpm under load, the car has been scanned by all mechs with no codes. I've spent a fortune changing everything with no luck. The fuel system is fine, eletrically the same with the coil pack and dfi being changed over and again with no luck with plugs and leads the same. I had the auto elect change the computer again no luck, he had a mech mate drive the car and he thinks the trans could be the prob (trans was recond 12mths ago before I brought the car???????).I also changed the lifters recently because they were a bit noisy (the engine has done 270) thinking that could also be the problem and again no luck. As you could imagine I'am ripping my hair out so any input would be fantastic......Cheers steve
    VT Acclaim Wagon
    Oct 2008
    Just a suggestion, check all your vacuum hoses for loose, split, hanging off (there is one at the back of the inlet manifold prone to this). check the valve that lets engine gas blowby back into the manifold for loose,(it should rattle when shaken) if the hose is hard or split, replace with new, check inlet manifold bolts and tighten if needed and only to specified torque. Make sure your fuel rail bolts are nipped down. Then look at your crank and cam angle sensors for dirt, oily deposits and clean. If any of your vacuum hoses are hard or split, replace them asap. Hope this helps
    vt wagon
    Jan 2011
    sydney
    Thanks for the reply graham,I intend on going right through the vacum side of things and the sensor issue is also valid being if they were dirty they would not always through a code....cheers
    vt wagon
    Jan 2011
    sydney
    I also forgot to add it only seens to do it when the temp rises above 1/4 as it is only very slight when cold.......
    VH and VT S2 Berlina ecotec
    Aug 2007
    Brisbane-northern suburbs
    i think i have a very similar problem as you, only when it at operating temp. very annoying....im a 3rd year app mechanic and i got no idea, i have checked everything eninge wise and serviced the auto...im thinking it something to do with the auto/torque converter...
    Aug 2007
    i thought it may have been the knock sensors stuffing up and retarding the timing, i tryed testing them but the results were inconclusive..
    vt wagon
    Jan 2011
    sydney
    yeh,it's doing my head in. I though about torque converter lockup but the mechs said it would be doing it all the time.....as suggested by graham I'll check the CAS for dirt ect, as the car was covered in red (desert like) dust when I brought it ???......it's worth shot,so if you figure it out let me know...cheers
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    im a newb but im gonna express my opinion anyway... so correct me if im wrong C=
    if there was a problem with the lock up then take off would be sluggish as it wont allow the engine to rev more then the gearbox right?? and once you get over 2400rpm you will have more power to get going so thats why it is only sluggish under 2400rpm if that makes sense
    just a theory as i've learnt a little bit about torque convertors :P
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by VH commodore View Post
    To test the knock sensors,just tap the alternator bracket or engine block with a hammer.The revs of the engine should noticably change if the knock sensors are working properly.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    hey foxrox, i've been chasing the same problem with my vt for about 12 months. i've replaced every sensor on the engine,new plug and leads twice(just incase the first set were dodgy) new coils and dfi module, new injectors, new inlet manifold gaskets, new vac hoses,new air flow meter to no avail,it's still the same. i'm fitting a new harmonic balancer and crank angle sensor this weekend to see how that goes. if that doesn't work. i think i'll throw 20 litres of petrol and a match at it!
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    Quote Originally Posted by 97bermudacalais View Post
    ... I think i'll throw 20 litres of petrol and a match at it!
    have you seen the price of fuel!!!!
    varies
    Jul 2008
    gone
    oh, on topic.. soz..
    I'm thinking CAS would be a good check first (easy)
    But it sounds like your trans is locking up way too early... and it's only an effective lockup as it gets warmer.
    drop by a trans shop mate, about 30 seconds of driving and they'll know if it's the trans!
    (Or yourself, if you stab the loud pedal from a standstill, what revs are you getting? also note in gear at speed with lower revs, if you apply another 1/4 throttle do the revs increase in that gear or is it maintaining revs and just loaded up?)
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    thanks coast! thats pretty much what i was getting at but as i said... im a newb :P
    Aug 2007
    the converter on mine isnt always locked...but i found when it does lock up at around 70 kph it takes its time un-locking when ur speed drops.....the prob seems to be related to temp as its much worse when at operating temp
  15. #15
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    replaced harmonic balancer abd cas last week end. still hasn't fix it. i was thinking some sort of heat sok issue, then this morning when i went to leave for work my radiator decided to drop its contents all over my garage floor. i'll replace that tommorrow and see what happens. don't trust you factory temp gauge either, mine sits half way between 1/4 and1/2 but the coolant temp was accually 112degrees! WTF!
  16. #16
    showbags's Avatar
    VT Calais,F6E
    Dec 2009
    replaced radiator, replaced coolant and bled system. went for a drive-all symptoms gone. running perfectly. 32 degree day went cruising around town for 45 minutes in stop start traffic(usually it would only take about 10 minutes to start playing up).
  17. #17
    vt wagon
    Jan 2011
    sydney
    Hey there,so do you thing it could have been your radiator all along? and have you had any problems since.....
  1. flat spot
    By biddy in forum V8 Development and Modification
    Last Post: 19-01-2009, 09:25 PM
  2. flat spot in v6
    By kniever in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:42 PM
  3. flat batery...then loss of power when jump started
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2007, 10:36 PM
  4. Flat spot :(
    By Uber_Matt in forum V8 Development and Modification
    Last Post: 28-08-2007, 06:44 PM
  5. VK flat spot down low
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-06-2006, 12:09 AM
