Results 1 to 3 of 3
Thread: lpg problems...
    vt v6s
    Oct 2010
    emu plains
    Default lpg problems...
    erm...dunno what happened..didnt use lpg for about 3 wks(,on petrol) then filled up lpg but when i started it on petrol and switched it to gas it cut out,,,,then it wouldnt start on lpg or petrol...then it all iced up(literally) everything iced up and car would not start for about 2hrs..then next morn it started on petrol..flicked to gas and no start..flicked to petrol and wouldnt start for about 1-2 hrs again..any ideas anyone???HELP..
    VT Calais
    Mar 2009
    SA - Victor Harbor
    mine iced over, it ended up being poor quality radiator water, it clogged it up and it froze over, also check to see if actually have water in radiator
    torch is offline Banned
    vz
    Dec 2010
    carrum
    "everything" freezing over is a sign that coolant isnt circulating through the convertor(it will have a thin line coming from the rear tank, a thicker line supplying the vaporised lpg to the mixer/carby/manifold, and two heater sized water hoses going to it + maybe some other electrical lines) . The flow through the convertor is necessary to transfer heat to the lpg to change it into a liquid. Without the coolant giving it energy, it takes that energy from the surrounding air, and the body of the convertor, hence it goes icy cold and freezes things up. Sometimes it will freeze coolant withing the convertor if the flow through it isnt high enough.
    Firstly, check that your coolant level is ok.
    2ndly, get the car running on petrol and up to operating temp and feel the hoses going in and out of the convertor. If coolant is flowing the hoses should both be at least as hot as the top radiator hose, if they are not, then possibly a blockage in the convertor or water pump problem.
    If the coolant level was low and you top it up but still the hoses going to the convertor are not warm, then its possible that an air lock has made its way there. One solution is to bleed the convertor. One way to do that is to undo one of the hoses to the convertor at the engine block, do the hose that is positioned higher on the engine, use something to stop the water gushing from the engine where you disconnect it, your finger will do!
    Undo the radiator cap.
    Put a garden hose into the convertor hose and turn it on gently, run the hose until water exits the top of the radiator.
    Stop the garden hose, put the rad cap on, and reconnect the convertor hose to the engine block quickly to ensure that most of the water stays in the hose. Run motor and check for convertor hose temps, recheck rad level.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. help!!! ecu problems
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2008, 05:05 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
