Results 1 to 2 of 2
Thread: VT horn issue
    VT II Olympic
    Jul 2010
    Exclamation VT horn issue
    Hi guys ive been having some problems with the horn on my VT
    To start with the horn is extremely sensitive, the slightest tap on the steering wheel and my horn will beep. The other problem I have is that sometimes the horn just gets stuck on without me touching it. There have been occasions where i have been driving down the road (hands nowhere near the horn) and the horn has just gone off. To get it to stop i have to hit the horn. This problem has also happened twice when the car was parked. Ive been inside and heard my horn go crazy and so far the only way ive been able to get it to stop when im not in the car is to pull the wires out of the horn as the doors will not unlock when the horn is going off :S
    This is really starting to get annoying, atm im thinking about just buying another horn and running a remote button into the cab to avoid this problem. However i would like to be able to fix it if that is possible
    Any thoughts???
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    As far as I know there is a metal sticker behind the horn pad and this can start peeling (lifting off) which causes the horn button to make contact setting the horn off. If you do a search you might be lucky enough to find threads on this issue as it is quite common.
  1. VS Horn Issue
    By taylorsvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2010, 09:22 PM
  2. Horn issue...VX.
    By Johnny_VX in forum General Discussion
    Last Post: 17-12-2009, 07:31 PM
  3. VR Horn issue
    By lothaer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2009, 10:08 PM
  4. Horn Issue
    By rippen50 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-04-2009, 03:27 PM
  5. intermittent horn issue
    By Timmos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-01-2009, 12:34 PM
