Is anyone able to help please?????? I have a 1998 VT commodore s pack that wont start. I have replaced the starter motor and the battery is fully charged. Is it likely to be something in the ignition or maybe something else? Please help![]()
Hi,
More information is needed. What do you mean it won't start? what happens when you turn the key? Does it crank over or nothing happens? Does it appear to start but then stop immediately?
There are many things that can stop your car starting from dodgy key or iginition barrel, to faulty BCM, stuffed coils, bad earth connection, faulty fuel pump or relay, etc etc etc. If you provide more info, you'll get better responses.
Good luck.
