My dual fuel vt has been playing up when it comes to starting or switching over to gas so as a start im looking to replace the spark plugs, what i dont know is if new ones will have any affect on the LPG timing as i know that it functions differently to the petrol. any help would be great
just get everyday plugs they work fine
Also on the V6,the plug gap on duel fuel engines should be set to 1mm instead of 1.5 mm.
Stock plugs for a VT Ecotec are BPR6EFS-15, gas requires 1 heat range cooler which is BPR7EFS-15. That is the plug you should be using according to NGKs LPG listing
VYII Calais L67
Firstly go to a 1.3mm gap, and see how it runs. Bosch Ytriums are good, i use Champion Gold or the Bosch. Bosch also make a fine tip plug just for lpg i think with a 0.9mm gap. Try it as it will only cost you around $25. Get some good leads as well, Bosch ones, Eagle, i use Scorcher myself. Ice are good as well. You need a spiral wire type. If the rubber is high quality like the scorcher, the covers arent needed, even with extractors. I change my plugs out every 15,000-20,000k's. LPG is spark and electric picky. Keep those in check and you should be fine. Clean air filters are important as well. Goodluck.
How long does it take to start ?
i run holden stock plugs and i have no issues
car drives like its new![]()
Do you put your car in neutral and rev it a bit when you switch over?
