Results 1 to 5 of 5
Thread: VT V6 Air Flow Meter
    98 VT Wagon
    Oct 2007
    Default VT V6 Air Flow Meter
    So took my car to the trans place this morning and he suggest that the car is running rough as well as the trans changing a little erratically. He has suggested it has to do with the air flow meter.......tells me it needs to be changed, how hard is that to do is it something I can do. Do most of the work on my car myself.
    Cheers, Daz.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    very simple to do
    its at your air box and has a clamp either side
    and one connector on it
    undo clamps
    undo connector
    take airbox out
    remove afm from intake pipe
    replace with new (there is an arrow saying which way around it should be OR if second hand and cant see arrow fit it same as your old one)
    reverse as above and your away
    if the engine light is on because of this afm fault then you might need to clear codes its in these foroumns on how to clear them yourself
    fyi im having a rum right now!~
    vs commodore
    Oct 2009
    Tamworth NSW
    Its more likely to be a faulty TPS (Throttle Position Sensor), as the auto transmission uses this sensor to help regulate the shifts etc.Ive read a lot of times on here how a faulty TPS has caused erratic behaviour with the auto transmission.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    98 VT Wagon
    Oct 2007
    Will check it out, thanks for the help.
  1. Air flow meter???
    By damankerrison09 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-08-2009, 09:24 PM
  2. Air flow meter
    By Leebo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2009, 09:24 PM
  3. Vt air flow meter
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:22 AM
  4. Air Flow Meter Help
    By Statesman94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2005, 11:01 PM
  5. LS1 air flow meter
    By I LIKE COMMODORES in forum General
    Last Post: 01-09-2005, 02:43 PM
