Results 1 to 11 of 11
Thread: Radiator Issue.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Default Radiator Issue.
    Hi guys over the past few weeks i have been noticing coolant loss from my radiator thought it was the hose. that was replaced then i found a tiny crack in the tank so i plastic patched that and now its leaking from where the tank joins the alloy.... Any ideas on what to do maybe replace the tank or is there a way to replace just the seals in it?
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    radiators are cheap ,better of replacing it rather than patching it, patches wont hold the pressure anyway.
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by The1 View Post
    yeah thats what i thought i did plastic weld it so the tank should hold fairly well was only a very very small crack that would most probably dissappear when it heated anyway i more talking about the seals but like you said its better replacing it then repairing it.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    fitz_vt's Avatar
    Nov 2008
    brand new auto barn 86.25 put it on order as holden wanted 400 repco wanted 330 and upull it wanted 90
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    do an exchange with a radiator shop new for old and put a new one in
    the cap generally lasts half the life of a radiator too soo get a new cap while at it
    and the coolant replaced and flush engine with hose when hoses off too!~
    fitz_vt's Avatar
    Nov 2008
    yeah following the gregories manual ive got the all of the stuff i need bar the cooling system pellets do i really need to add them?
    VT Acclaim Wagon
    Oct 2008
    If you are using quality long life coolant, (Nulon etc) you do not need the pellets. Nulon gives an extensive warranty provided it is used correctly. 50/50 mix with distilled or demineralised water after the cooling system is flushed and drained. Knock sensors out for complete drain. By the way, it is a fairly unsuccessful operation to try to fix the end seals on a plastic tank radiator. They fail most times. Cheaper to replace radiator.
    fitz_vt's Avatar
    Nov 2008
    yeah i looked at a seal kit and then a new radiator and with time factored in and the guy teling me that the sucess rate hes seen was 99% fail.... i decided it would be best to get a new radiator which should come in today and im using Tectaloy Xtra Cool Gold which is supposed to treat 15 litres . phew demineralised water tectaloy coolant says to use regular tap water ......
    VT Acclaim Wagon
    Oct 2008
    I am a bit old school, even Holden says to use "clean, clear water" I have been told in the past that you cannot trust the water in most state capitals, esp Qld, SA and Perth as their water is somewhat hard. Using demineralised or distilled water helps the anti-corrosion agents in your coolant to do their job wherever you are and it's cheap as chips so I use it anyway.
    fitz_vt's Avatar
    Nov 2008
    But if you think about it spending that little extra on demineralised water will make the coolant last a little longer..... you dont need to trust the mains watersupply to be clean and its often got that many chemicals in it that well are safe for human consumption might not be safe for a cars engine ...... now the knock sensors does anyone know what size these are (eg 18mm 19mm etc) as i have to get a socket bit to get them out and well i cant get it without the actual part out so if anyone knows what size they are that would be a fantastic help
  1. should external trans radiator be inline with radiator compartment
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2010, 10:50 AM
  2. 1995 VS Auto V6 Radiator Issue
    By ETH4N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2010, 11:53 AM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. Radiator Issue!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2006, 12:40 PM
  5. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
