Results 1 to 6 of 6
Thread: new vt alternator buit alt. light still comes on.
    VT Exect.wagon
    Feb 2008
    Default new vt alternator buit alt. light still comes on.
    The alternator light on my 98 VT 215,000k was coming on after about 10 minutes of driving.When I switched off the motor for a while and started driving again it would stay off for about another 10 - 15 minutes and then come back on again. Somedays it never came on at all, even after 40 minutes of driving.
    So I sprang for a new OEM alternator Bosch 100 amp. the exact replacement for my original one, and it ran for ten minutes but the damn alternator (not battery ) light came on again.
    I checked out the forum, but the only similar experiences seem to involve the bat. charging light.My bat.charging light is normal and does not come on while driving.
    I ran the computer thingy and it was 19, which is the fuel sensor, and which I knew I had a bit of problem even though I cleaned the hell out of it all and especially the throttle plate etc. It did run much smoother, in fact it ran as good as it ever did so I was surprised that this was still a problem.
    Back to the alternator though - anyone have any ideas?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Check the connections at the alternator and the earth connections, make sure they are clean and tight.
    MY RIDE
    VT Exect.wagon
    Feb 2008
    Yeah thanks accentstencil. I just installed the brand new alt.yesterday and everything is clean.
    I just can't figure out what else it can be.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    which light is it exactly?
    alternator charge light is the one that looks like a battery.
    it sounds like the engine light is coming on.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    19 Throttle position sensor (sticking open)
    how to check codes if need
    http://forums.justcommodores.com.au/...-car-pics-.jpg
    list of codes
    Checking error codes VT/VX
    that code is for the tps sensor not reading that its closed or it isnt closed
    check the screw for throttle plate hasnt been adjusted so plate doesnt close all the way
    else likely needs new tps
    fuel level sensor? dont think you have right code description there
    VT Exect.wagon
    Feb 2008
    Good question Wamboin. In all the years that I have owned this VT this light has never come on when the motor ws running. So when it came on I checked the alt. and when I found it was not charging I assumed it was the alt.light,but in fact it was the engine warning light - it seems I have 2 seperate problems at the same time.Charging and TPS.
    Yeah db, iI have read the code 6 times and it definately is 19. I was just calling it by the wrong name.
    I did clean the TPS and throttle body out as I posted earlier and it made a terrific difference.Good as new,so i was surprised that the light came back on again. Anyway I will chech the throttle position as you have suggested and then I will be taking it to my mechanic today and see what he has to say if still a problem Thanks all for your help.
  1. Alternator warning light
    By VYLUKE89 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2010, 12:44 PM
  2. Engine light??? Alternator light????
    By 11gothevt11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2010, 05:37 PM
  3. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  4. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  5. VX Alternator Light Always on.
    By Raggyman in forum Electrical Wiring / Questions
    Last Post: 25-10-2005, 07:34 PM
