Results 1 to 4 of 4
Thread: HOW to remove front right guard from vt
    vt berlina 99
    Jan 2011
    lilydale
    Default HOW to remove front right guard from vt
    do i need to remove side skirt any suggestions PLZ
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I'm not a 100% sure but I'd say you'd need to remove the bumper, head light and there woul be bolts under the bumper, unbeaten the door and the guard, on top of the guard where it meets the bonnet.
    Maybe check out the how to section if there isn't a guide there then maybe you could make one?
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    yeah probably easiest to fully remove, rather than partially remove (on the right side) the bumper.
    I couldn't work out how to fully get off the side skirt, but removed most of the screws so I could pull it back to get to the guard bolts/screws.
    You will need the right sized flat head screw driver to remove the torx screws holding in the bonnet strut to the top of the guard in the engine bay, support the bonnet with a piece of wood or something so it doesn't come down of your head.
    After that it is just a matter of removing ALL of the bolts to get the guard off.
    The hardest part is re fitting it and getting the panel gaps right.
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    he he he, i took mine to a panel beater. so much easier. must be getting lazy
    i do as the voices tell me
  1. Remove Front guard?
    By Andrew_Guppz in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-03-2010, 05:25 PM
  2. Front left wheel flush with guard, front right within guard. What's goin on?
    By Evman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-02-2007, 12:22 PM
  3. How Do I Remove Black Door Guard
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2006, 05:40 PM
  4. How do I remove the drivirs side sneaze guard (Wind/Rain deflector)?
    By uriah in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2006, 01:06 PM
