Results 1 to 10 of 10
Thread: Trannie Issue
    VT Acclaim S2 Wagon
    Nov 2009
    Default Trannie Issue
    I have a Series 2 Acclaim Wagon with an Auto Trannie, I have been having a problem with it for a few months now so thought I would see what you guys think it may be.
    While I am driving my car the check engine light comes on but just before it does the car gives a bit of a shutter which feels like it comes from the trannie. Now, while the check engine light is on and I go up a steep hill the trannie wont kick down gears or worst of all if I am over taking it will not kick down.
    When the engine light isnt on and I am sitting on 100 - 110 it is still in third gear and to get it in to fourth i have to stick the boot into the accelerator and lift my foot off the accelerator to get it to go in to fourth. When I go to work i have to go up a hill but have to turn off to go up the hill so when I slow down it kicks down to second but as I start going up hill it will kick in to third and then fourth which feels like I have no power but I have my foot nearly flat to the floor and then it will drop back to second then as it picks up speed it will kick up to third and then fourth.
    This is really starting to annoy me as i am only getting 450 kms to a tank of fuel where I was getting 800 kms to a tank.
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    Sorry, i've tried reading your post a few times and I can't figure out what you mean.
    As a start however, check this Checking error codes VR/VS (Revised) and see what has triggered your 'check engine' light.
    as far as kick down problems, i'm not much help cause my VN uses a cable which i can adjust/check and I believe the VR & VS use electronics.
    So best you check what the error code is, cuase I have a sneaking suspicion it may point you in the right direction.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Hes talking about a VT, not sure VR/VS error codes will help him. Although there will be something similar for VT.
    Best RPG ever
    varies
    Jul 2008
    gone
    Quote Originally Posted by 2DIE View Post
    how right you are... i must remember to read with my eyes open... HAHA
    varies
    Jul 2008
    gone
    VT SII 5.7 LS1
    Jan 2008
    Albany, WA
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by TA 91 WA View Post
    Could it possibly be the solenoids inside the transmission?
    Sounds like it. 3/2 shift solenoid could be the culprit
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VT SII 5.7 LS1
    Jan 2008
    Albany, WA
    Quote Originally Posted by SabbathSS View Post
    Very easy to get the part from your local transmission place or even on eBay as the 4L60E is an extremely common trans. I'd pay no more than $50. Can easily find it cheaper.
    99 VT Acclaim Wgn V6 Auto
    Jan 2007
    Hi VT Fan
    Sounds like your transmission might be slipping. On my last coupla of general services the mechanics found my car gave out Error 85 which is (something like) Transmission Slipping Not Matching Engine Revs, or something like that. Might pay to take it to a transmission specialist.
    Mine does it when going to work on the Monash, doing 100kmh at just below 2000rpm then all of a sudden the gearbox shudders and Im still doing 100kmh but at 3000rpm and it wont change till you turn the car off. Let me know if that happens to you. If it does, probably same as mine. Just nursing it till I get the money to fix the gearbox. Bloody cars! haha
    VT Acclaim S2 Wagon
    Nov 2009
    My car sounds similar to your problem mbvp73.
  1. VT Calais Trannie
    By Stumpee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2009, 04:24 PM
  2. VT Calais Trannie
    Last Post: 18-01-2009, 09:22 AM
  3. trannie probs
    By mattheman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-11-2005, 06:41 AM
  4. VN Auto Trannie problem
    By scottvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2005, 09:56 AM
  5. Swapping Auto Trannie For Manual.
    By d hsv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2004, 04:55 PM
