Results 1 to 13 of 13
Thread: VX high rpm rattle/noise
    02' VXii Exec 9C1
    Aug 2009
    Default VX high rpm rattle/noise
    hey guys
    i have notice a really funny noise that my vx s2 makes.whenever it hits high rpm just before the gear change it makes a rattle likes somethings loose.my mechanic couldnt find anything wrong with it and you can only hear it if the stereo is off but i was curious to know if others have had the same thing.for example you hear the engine roar and then you hear the weird noise then the car changes gear.i think its most evident on gear changes from 2nd to 3rd but it could be 1st to 2nd aswel.
    im sorting out another problem of my fuel system as i write this and im unsure if the two problems are related as i encountered this noise yesterday and it rung out and the car wouldnt change gear like the box flanged.its a 2002 seres 2 VX V6 auto.any help would be great.thanks
    First Car: 01' VX S
    Second Car: 02' VXii Exec 9C1
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    What kind of noise is it (metallic, ping, clang, bang)?
    02' VXii Exec 9C1
    Aug 2009
    vx s pack manual
    Aug 2011
    kingaroy
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by VXS5speed View Post
    Sounds like a broken engine mount to me is it manual or auto
    If the engine mount was broken, you'd know it. As he revved the engine would make a lot of noise and you'd feel it crashing around in the bay (I know from experience in my car, it was like a fat kangaroo jumping on my car when gear changing).
    Otherwise, I can't think of what it might be thought, just I think it unlikely to be a problem. Certainly I doubt the mounts have collapsed, they could be a little damaged and rough though - might pay to have them checked.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    vx s pack manual
    Aug 2011
    kingaroy
    vx s pack manual
    Aug 2011
    kingaroy
    VXSS
    Aug 2011
    if its in the high revs and it sounds like an empty paint can rqattling round like crazy.. but not asloud it could be pinging...
    shit bit of fuel maybe and its leaning out?
    OH! haha i just read your having problems with your fuel system maybe its leaning out bad? dont give it shit till you sort out the fueling dramas my buddy..
    Dan
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Mine and another mate of mine with a VX S2 both have this weird muffled rattling sound at high rpms. it sounds like its coming from the dash pad, never actually cared enough to figure out what it was though as it only happens at high rpms.
    Is this the same for you? Or does anyone else know what this could be?
    2003 VY BERLINA
    Jun 2010
    WYNDHAM VALE
    Thumbs down VX high rpm rattle/noise
    hi i have a 2003 vy berlina ex cop car and i have noticed when i stick my foot down, overtaking or at the lights, when it gets to about 3500rpm i have a very loud vibration noise coming from what appears to be under the bonnet some where. i have looked and looked for the answer to this problem but have been unsuccessful. even Holden told me its normal/common but i dont believe that for a second. its really starting to piss me off cause its only when i stick the foot down it makes that terrible noise. and yes it seems to be right before the gear changes. if any one out there does know a solution, please dont hold back and share with us. thanks
    jamesmp's Avatar
    jamesmp is offline The Photo Journalist
    MY10 VE Commodore SV6
    Dec 2010
    Brisbane, QLD
    My manual VX S did the same when you pushed it out to 3,500-5,000rpm. Holden said it was probably an exhaust rattle.
    My portfolio at RailPictures.Net!
    My portfolio at Flickr!
    This reply is intended to provide general information only, without taking into account any member's personal circumstances.
    2002 Holden Calais v6 super
    Dec 2010
    Ipswich Queensland
    2003 VY soon to be boosted
    Aug 2011
    West Auckland
    I currently have the same sort of noise in my VY, anytime I ring it out over say 5500-6000rpm, just before the gear change, there is kind of an "almost" rattle noise, almost sounds like something metallic in the left hand exhaust bouncing around, I am currently putting in a rising rate fuel reg to do away with the original and to where I will bump up the pressure slightly to make sure it just isn't leaning out and having a slight ping at higher rpms under load ( I run 98 octane with a +10 Booster so fuel should be mint ), a new PCM with A/M tune has gone in and the sound is still there, my fuel reg may have some issues as after the car has been sitting overnight it will take 2 turns to start ( not every time, sometimes first pop ) but if I drive it and stop then start ( at any temp ) it will start instantly every time ( vr vr vroom ) , I'm guessing the fuel pressure is being released though a worn regulator, if that doesn't resolve it I may bring it down to the timing chain getting loose/worn or valve train noise
  1. VY Series 2 V6 Rattle at mid-high rpm
    By VYCamo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-03-2010, 01:55 AM
  2. AC Noise in Cabin - High Pitch Noise
    By yor71 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2009, 05:47 PM
  3. High pitch noise @ high rpm
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 10:00 AM
  4. Rattle Noise
    By PuNkuS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2005, 06:25 PM
  5. rattle noise
    By V6VL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2005, 02:27 PM
