Results 1 to 6 of 6
Thread: VX 2 toe linkage arm adjustment
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default VX 2 toe linkage arm adjustment
    Checked the freq questions and could not find how to adjust this arm, I had a look on my "lowered" SS yesterday while swapping the exhaust and changing the diff oil, it had 2 22mm connectors on the sleeves and what seems to be a 18mm connector on the middle of the thread I assume its 18mm as my 17mm is to sml and my 19mm is to big and my imperial set does not have anything to fit it. so what do you do? holding the outer while turning the inner was my first thought but how long it the thread? I don`t want it falling out is it easier to adjust the arm off the car? or while its on is it easier with the wheels on the ground or up in the air? did try turning it with a 19mm but was amazed it would be a 18mm as I`ve never seen a 18mm in any set.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Its lowered on ssl so by doing this I do understand that it won`t fix the problem but it will help it a bit.
    ve sv6
    Aug 2010
    where are you going to adjust it too? better of leaving to a wheel aligner.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    With so many people going low I`d hope for more responses, if i get some right info I`ll do a how to.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Just pay for a rear wheel alignment . If you don't know what you are doing you will stuff the tyres up in no time .
LinkBacks (?)
  1. Automatic transmission shift linkage
    By vzrath in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-05-2010, 08:29 PM
  2. Windscreen wiper arm nut stripped... New linkage ??
    By crazyspoon05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2007, 10:39 PM
  3. Quadrajet secondary flap linkage ???
    By TEMPA1 in forum V8 Development and Modification
    Last Post: 20-03-2007, 10:26 AM
  4. Gear shift linkage? What?
    By Scooter79 in forum General
    Last Post: 19-08-2006, 09:54 AM
  5. i need linkage
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 08:12 PM
