Results 1 to 6 of 6
Thread: Supercharged Vt Commodore lacking in power
    1999 Vt Calais Supercharged
    Jan 2011
    Default Supercharged Vt Commodore lacking in power
    Hi my name is Simon and i have a 1999 Vt Calais Supercharged i have extractors and exhaust, cams and a 10psi Pulley Upgrade. My car seems to lag for a good couple of seconds when i put my fut down before any power kicks in and its only boosting at about 5psi. Does anyone know what this could be? Any help would be great thanks.
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    could be a few things, air leak somewhere maybe hence the low psi *just a guess*
    could also check all the spark plugs and leads, and maybe a service ie. new oil and oil filter, fuel filter and air filter
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Depending on the cam specs, this has likely dropped your boost by a couple of psi, but you should still be seeing a bit more than 5psi. Everything in good working condition on a stock l67 should see about 5-6psi. My guess is your boost control solenoid is faulty. They are notorious for developing this fault and robbing you of boost as they can prevent the boost bypass butterfly from fully closing (full boost). You can either replace the solenoid, or bypass it.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VS L67
    Sep 2007
    BrisVagus
    As cander24 said, check the boost bypass solenoid on the back of the passenger side head. Most people disconnect this. I would also be checking your engine mounts.
    The L67's love to eat engine mounts, as they wear the pin that goes through the bottom of the mount starts to wear on the K Frame which in turn sets off the knock sensors and the ECU/PCM then starts to pull bucket loads of ignition timing out.
    Next problem is that if you have installed CAMS you may have one too many, joke.
    You may also want to double check the cam installation, you may have set it up with too much advance or even too much retardation.
    The best site to get great information on the l67 is L67torque dot com
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    Jan 2011
    When i bought the car it already had the extractors and exhaust, cams and the pulley. I havnt done any mods to it i have only serviced it and replaced spark plugs, spark plug leads, coil pack and got the transmission fully reconditioned with a stage 2 shift kit. Can anyone give me a tip on how to disconnect the boost bypass solenoid ill give that a shot. Another thing is my car when it is cold boosts at about 10 psi and seems to run a lot better but as soon as it gets to operating temp it starts to lag. Thanks
    Aug 2008
    NSW South Coast
    Quote Originally Posted by Decicrate View Post
    Simmo_91, check out this forum. There's a great wealth of knowledge there specific to the L67. In the tech section there, there's a how to on this.
    PM Me For Details
  1. VP lacking power and making small backfire noises.
    By kristianmaaten in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2010, 10:41 AM
  2. Replies: 8
    Last Post: 19-06-2010, 06:34 PM
  3. VT II S V6 Lacking power on LPG
    By MattyC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2009, 12:12 AM
  4. VS lacking power
    By kurt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2008, 06:08 PM
  5. new gearbox in but lacking power
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2006, 10:17 AM
