Results 1 to 6 of 6
Thread: engine light with a differance?
    VT SS 5.7 GEN 3
    Jan 2011
    geraldton
    Default engine light with a differance?
    hey guys,
    im new to the forum, i have a gen3 vt ss(5.7) man.
    now the engine light comes on when the temp gauge reaches just past the C
    i have no lost power everything is fine (oils and things)
    i can turn the car off and straight back on and the engine light will stay off untill im in motion (maybe ten mins down the track).
    ive checked the error fault codes and it returns with 12 which im assuming is ok because that means it hasnt logged any codes.
    so whats should i check next guys your ideas would be appreciated
    thanks
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Try reseting the system by disconecting the battery for a few minutes (make sure you have the radio code)
    VT SS 5.7 GEN 3
    Jan 2011
    geraldton
    ok buddy im on it ..... aftermarket sounds so no code needed . ill keep ya updated
    cheers
    VT SS 5.7 GEN 3
    Jan 2011
    geraldton
    no luck .............. as soon as it hit above the c on the temp gauge it came on , had the battery dis connected for around fifteen mins.
    could it be , temp sensor ,possibly oil pressure sender or something simalar
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Gen3 PCM doesnt show codes like the earlier ALDL setup.
    You'll have to get hold of a scan tool or take it to a mechanic to find what the code is.
    VT SS 5.7 GEN 3
    Jan 2011
    geraldton
    is it expensive to get them to put a tech 2 on it . ive heard some horror storys , ha ha ha
LinkBacks (?)
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. how do i tell the differance
    By tallfella in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2008, 05:32 PM
  5. is there a differance
    By ratz26 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2007, 03:42 PM
