Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: clunk coming from front right wheel when turning
    VT commodore executive
    Jan 2009
    Default clunk coming from front right wheel when turning
    hey guys. you were really helpful with my diff servicing question and I hope the commodore experts here can help me diagnose.
    when turning at low speed I hear a clunk about 50% of the time coming from about the wheel area, it sounds bloody awful. its not a clicking noise or anything like that, just a violent sounding clunk. any ideas?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Could be a broke sway bar linkage.
    Have a look under the wheel, mounted to the strut with 2 bushes should be a thin 10 inch or so bar connecting to a larger bar (sway bar) with another 2 bushes. See if the link is still in one peice
    Sometimes they break and when turning knock each other.
    Ben
    There is no such thing as stupid questions, Only stupid people.
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Default Sway Bar Link Pin
    This is what youre looking for as suggested by TrikkBen
    I do also agree this is the first place to look
    Marked with the Arrows in the picture ( Its a picture on a VS, But is the same principle as the VT )
    Attached Thumbnails Attached Thumbnails clunk coming from front right wheel when turning-vs-triangle.jpg
    GSXR1000
    Apr 2010
    WA
    I've got a bit of a clunk coming from the front, sounds almost like it's from a similar area or more in the steering itself.
    only every so often though and it's a solid clunk.
    My sway bars links, power steering and shocks/springs have all been replaced in the last 2 months or so, any other things to look for?
    (will obviously check the sway bar links etc again just in case). (dont mean to hijack thread, but may have some relevance to what you're looking for also)
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by Mirkz View Post
    Suspension mounts/bearings? That's what it was on mine.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    Jan 2009
    Quote Originally Posted by TrikkBen View Post
    Ben
    i will check it out tomorrow. how dangerous is it to drive like this if you are correct?
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by brisbane_vt View Post
    Your handling suffers, and if you have a prang it could throw up some issues with insurance. Be careful in otherwords, get it fixed asap if the sway bar link is gone.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Id. look at a few things .
    One. What the first few posters suggested Sway bar links if theyre broken ,bent or incorrectly installed they will clink upon steering as the sway bar bushes have metal washers on them and they move out of alignment hence the clunk. another way to test this is to find a very bumpy road paticularly with manholes covers in the road that have sunk if you run over them and it makes a clunk noise or as rather rough its a suspension issue
    Two. If its comming from the steering area check your tie rod ends if the boots are deteriorated then these will make a clunck noise as they arent properly lubicated.
    IMPORTANT* if you have suspension components that are broken or faulty your vehicles handling will not be 100% this can cause alot of issues in handling and traction for your vehicle. in other words you can cause more damage by leaving it.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    Jan 2009
    well I got under there and had a really good look. Everything look in place except for a bit of rubber coming out of the right sway bar bush and it came off really easily. So I reckon thats prolly it?
    May 2010
    Youre probably right
    You could pick up a pair of link pins and bushes from an auto shop
    Noelathene or white line i think are the brand names about $30
    30 minute job to replace yourself
    Jan 2009
    Thanks for all the help guys. I knew immediately where to look thanks to this forum. Wish you could all have a beer on me!
    GSXR1000
    Apr 2010
    WA
    May 2010
    @ Mirks.
    Does your clunk occur whilst braking ?
    Or turning into a driveway or when the suspension needs to level itself?
    GSXR1000
    Apr 2010
    WA
    sometimes.. it only ever does it if I'm turning into a corner etc, sometimes it doesnt even do it for a while.
    heard it quite loudly tonight with the window down, even the missus asked what it was.
  15. #15
    VT
    Feb 2010
  16. #16
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    ive heard a rumour that the ball joints are rivited on and the rivets can wear, causeing a clunk, im about to have my mechanic put new ball joints in mine as i have a faint knock, im also planing on new d bushes on the swaybar as they are the only thing i havent replaced in the last 4 months
  17. #17
    May 2010
    @ Mirks
    Have you replaced any of the Bushes in the front end?
    Check my attached picture at the start of the thread for reference
    It may be Control arm Bushes marked with the Triangle and Square in picture above
  18. #18
    GSXR1000
    Apr 2010
    WA
    Rhin0o8, haven't replaced any of those, so will probably have a good look tomorrow if I can. Might have to pick me up a bush kit to freshen up the front end a bit.
    Either way, will try get the car up on the jack tomorrow to have a look underneath and see if I can locate!
  19. #19
    GSXR1000
    Apr 2010
    WA
    Okay took a quick look this morning.
    only got an old crappy jack to use, no stands/ramps etc so couldn't have a good look.
    Here's a couple of pics, I noticed the sway bar(?) seemed to be sitting high on the link bush leaving a decent gap, but I'm not sure if this is because the car was on an angle and the wheel still slightly touching the ground.
    Also found an oil leak that I'll have to look into Oil leaks make me sad haha
    Also...
    is this the starter motor ??? If not, what is it?
    and the oil leak.. just need to find it's source.
  20. #20
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    take it to pedders for a 14 buck check
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  21. #21
    VT
    Feb 2010
    I have been under my one today with the camera too, and I have the chunk also (left hand side)
    This is were I think its coming from
    Look at the size of that gap !! and there is only a rubber mount bush there.
  22. #22
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    i know im thread digging, but guess what, i have the same fkn problem, just got my car back on the road after a gearbox reco and its giving me the shits. no shops are open atm obviously. and there is nothing underneath that looks broken, tried moving things sway bar etc and i cant get it to do it
  23. #23
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    i also have to, ive replaced a heap of rubbers witch i was told could be the problem but its not. Next ill replace the power steering rack as its leaking any way.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  24. #24
    calais24/7's Avatar
    Jul 2009
    i have a feeling mine is a wheel bearing? cause i also have another vibration/ noise, can wheel bearings clunk when there fkd?
  25. #25
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by calais24/7 View Post
    No they dont,only constant winding noise which increase or decrease with the speed.
  1. VX clunk in front end when turning left
    By thepowerman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2010, 09:17 AM
  2. Clunking coming from front end when turning and going up a curb
    By pjnsuperg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-05-2010, 08:29 PM
  3. loud nocking noise in front left wheel when turning.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2009, 07:57 AM
  4. High pitched sound coming from front left wheel when turning
    By RonMan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 10:45 AM
  5. clunk/noise in front left wheel of vs
    By vsplook in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 04:41 PM
