Results 1 to 7 of 7
Thread: What's this, and where do I put it ??? - MACE CAI
    GSXR1000
    Apr 2010
    WA
    Default What's this, and where do I put it ??? - MACE CAI
    Hey guys...
    I've come across something that isn't on the MACE instructions for installing a CAI.
    Just wondering where I should be putting it or mounting it as there doesnt appear to be a mount on the CAI enclosure.
    Any help greatly appreciated, mid project :P Came off the side of the standard airbox.
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    thats your ignition module, why did u unbolt it? it should of been bolted to the strut tower somewere and my advice would be to leave it there
    doin skids for the kids and doughnuts for the grown ups
    GSXR1000
    Apr 2010
    WA
    it was bolted to my standard airbox which was completely removed for the CAI install.
    Figured it should be ok to bolt it to the chassis or something but if there was somewhere else it can go relatively easy I'd do that.
    rickybobby's Avatar
    rickybobby is offline shake 'n' bake
    VN S1 V6 T5, VR V8 T5
    Aug 2008
    MEL
    be very gentle with it and don't mess with it too much.
    i live in a lovely part of town and used to remove mine every night - i think i helped it die by doing this.
    very difficult to diagnose when they stuff up (unless you've got a working one out of someone else's car that you can borrow).
    anyway just mount it anywhere nearby if you can't mount it on the new mace airbox (which you probably can't).
    on the VR they are mounted directly on the metal (with nuts and bolts) surrounding the strut tower (directly behind the airbox) instead of self tapping screws into the airbox - you might have to do this VR style mount to get it out of the way.
    GSXR1000
    Apr 2010
    WA
    Cheers ricky, just had a look, I can get it to fit quite easily just under the pod filter, just about to screw some holes into the CAI box so I can mount it.
    Mar 2008
    You can screw the module to one of the airbox mount points, within the box itself.
    Please keep us posted
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    GSXR1000
    Apr 2010
    WA
    Hey Steve,
    Managed to fit it up easily last night, just drilled a couple more holes and mounted it at the bottom.
    Nice and easy, out of the way.
    Posted some pics of the finished result in the thread about my car.
    Very happy with it so far, has changed the sound of the car a lot, performance seems to be a bit better too.
    The initial suction noise will take some getting used to but it settles down once the car warms up so all good.
    Thanks for all your help Steve, great communication and service, answered all my questions so far.
    Fitting up the throttle body on Saturday.
  1. mace for other car manufacturers?
    By vk.jonno in forum Mace Engineering
    Last Post: 28-04-2010, 07:04 PM
  2. mace cai on vz. HELP?
    By henrytad in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-09-2009, 10:41 AM
  3. MACE alloytec CAI
    By listen_to_slayer in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-04-2009, 04:49 PM
  4. mace cai
    By revan_vs in forum V6 Development And Modification
    Last Post: 26-03-2009, 08:04 AM
