Results 1 to 3 of 3
Thread: VT V6 ENGINE Swap
    VT Executive S2
    Jan 2010
    Illawarra
    Default VT V6 ENGINE Swap
    Alright about 8 months ago i cracked my heads,replaced them fixed the problem but the found a tapping noise..coming to the conclusion that my top and bottom end are ####ed car still goes goes hard.
    But im over the noises and the little other problems here and there..
    i want to replaced the engine with a second hand one..mayber even wack a supercharger on there..
    new exhaust ect
    Is there any sort of guides i can follow i mean i no a fair bit but just somthings i aint got a clue.
    also please recomend any exhaust ideas
    cheapish and nice sound
    cheers
    VN S
    Aug 2009
    might be cheaper/better to get it rebuilt if your puttin a supercharger on, then you would beable to get it upgraded depending on your money plus know what sort of boost it can handle and so forth, the tapping could just be tappets they always tap they just get louder after time, and besides the noise i dont think it will do anythin to the car, easy fix either way its only in the top of the engine, getting another engine will still cost you a few hundred then you could have similar problems or worse even.
    VU Ute 3.8 S
    Mar 2011
    If your gonna do an engine swap you may as well chuck an L67 in it. You can find them on eBay for around $2500 and they've all been tested and cleaned and come with all bolt ons.
  1. VS gen 3 engine swap
    By a-drain in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2010, 09:40 PM
  2. vt engine swap
    By MasterVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 02:00 PM
  3. VT engine swap
    By w2407 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2009, 07:25 AM
  4. VN > VT engine swap
    By stuee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2009, 01:59 PM
  5. vr-vs v8 engine swap
    By little mick in forum V8 Development and Modification
    Last Post: 26-07-2008, 09:16 PM
