Results 1 to 5 of 5
Thread: Vt steering wheel problem.
    Jan 2008
    NSW
    Default Vt steering wheel problem.
    when you take the key out the keyhole pops out a bit so then you can lock the wheel. but my keyhole stopped coming out today and i cant lock the wheel. i tried giving the steering column a little love tap and it worked, but only once. any ideas on how to fix this???
    Holden Commodore VT
    Dec 2010
    sydney
    VT
    Feb 2010
    A little WD40 or graphite grease down the keyhole then put your key in and turn it back and forwards a few times, it should fit it up
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Pull the barrel out and stretch the spring on the end of it.
    Just remove the trim around the steering column and on top the the barrel should be a small hole. Poke something into the hole while turning the key to ON and pull the barrel out. You will see the spring on the end of it.
    Dont stretch it too much just bit by bit and put it back in and test it. Clean all the gunk out while its out as well.
    Silver Certified.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    worked for me
    Quote Originally Posted by ])R@G()N View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. HSV GTS Steering wheel vs SSV Steering wheel / Re trim ?
    By geo41e in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-12-2010, 04:53 PM
  2. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  3. Custom Steering wheel - Air bag light - PROBLEM!
    By STUEY HOLDEN LOVER YEP in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2010, 05:17 AM
  4. VX Steering wheel controls / function problem
    By ekles in forum Electrical Wiring / Questions
    Last Post: 09-02-2008, 03:20 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
