Results 1 to 6 of 6
Thread: Uneven Brakepad wear --
    VT Acclaim WAGON
    Apr 2009
    Default Uneven Brakepad wear --
    Hi All
    Replaced my front pads on the vt wagon a few days ago. Tested and drove the car for a day before having the front castor bushes and wheel alignment done at the mechanics. Mechanics test drove the car and siad all was ok.
    Now the next day the wife complained about a knocking noise coming from the drivers side front.
    I checked the brakes to see if anything was wrong and found the pads to be nearly completly worn on both outer edges.
    I also checked the passenger side and found the same, pads worn on the outer side.
    Any ideas?
    Cheers Mick
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    When you changed the pads, did the piston push back evenly? If it's wearing unevenly, it sounds like the pads aren't parallel to the disc when they make contact.
    How old are the rotors?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    2002 VX II Acclaim
    Aug 2008
    thats weird for a single side to be completely worn out in a single day.. however if the pins the caliper sit on arent lubed up again after replacing brakes, it will cause this.
    VS L67
    Sep 2007
    BrisVagus
    When you say worn on both edges do you mean that the leading and trailing edges of the pad are worn and that there is only a section of pad in the middle of the brake pad that is in contact with the rotor?
    There are a lot of pads that are released like that.
    Do they look like the one in the top of the picture?
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    VT Acclaim WAGON
    Apr 2009
    Yes thats what they look like mate.
    Just chasing this damn knocking noise.
    Cheers Mick
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Did thay mach the discs
    Quote Originally Posted by zxtc View Post
    hi all
    replaced my front pads on the vt wagon a few days ago. Tested and drove the car for a day before having the front castor bushes and wheel alignment done at the mechanics. Mechanics test drove the car and siad all was ok.
    Any ideas?
    Cheers mick
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
LinkBacks (?)
  1. Uneven Mufflers
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-12-2010, 06:11 PM
  2. uneven pad wear
    By sneezy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2010, 04:37 PM
  3. Uneven Boot
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2009, 12:20 AM
  4. Uneven rear tyre wear
    By Scooter79 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-03-2008, 10:19 PM
  5. IRS and the uneven tyre wear
    By commod8 in forum General
    Last Post: 25-02-2006, 07:49 PM
