Results 1 to 9 of 9
Thread: How to get to the seat belt tensioners - VT II
    VTII Gen3
    Dec 2010
    Default How to get to the seat belt tensioners - VT II
    Bit of a newb question, but how do I get to the seat belt tensioners in my VT II?
    The rear seat belts are really slow to retract so I want to get in to them and clean/lube to hopefully make them a bit quicker.
    I have done a search and found a few tips on how to clean them up but can't find what bits of trim I need to remove to get to them. Any help appeciated!
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I have no idea but be careful, I read they have exploding mechanisms that locks the seat belt in a crash. Not sure how much "exploding" they do when they go off but it sounds bad enough to put me off playing with them.
    Best RPG ever
    VX Calais LS1, VS Calais L36
    Mar 2010
    The exploding bit of the seatbelts is the pretensioner, which is part of the buckle assembly, not the seat belt retractor itself.
    The retractor roll sits inside the base of the B-pillar, from the service manual it looks like you just undo the screws and off comes the cover.
    vx custom 600RR
    Oct 2010
    the rear seats don't have pre tensioners
    only the fronts which are attached to the seats
    Mar 2010
    Oops - oska is right. I just assumed we were talking about front seats here.
    For info, a new rear belt is about $120 from Holden. Mine has the same issue and lubricating things up made very little difference.
    1998 HSV VT GTS 5.7 Stroker
    Mar 2010
    Tauranga NZ
    If your belts are slow to retract back, do this.....Firstly remove trim panel,pull webbing right the way out to check to see if it is twisted.If so you'll have to do a half twist on the webbing and pull it back though.If it's not twisted,check the top hanger guide to see if theres any buildup of shit on it.(clean)Then spray the hanger with a silicon spray.That normally works.
    But if your webbing are starting to get hard,you maybe up for new belts.Hope this helps.
    vu maloo
    Jan 2011
    Quote Originally Posted by 1998GTS View Post
    hello,,l sell those for 35-40 second hand, but in good nic,, let me know if you need anything Holden Commodore Parts
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    were in melb are you?
    Quote Originally Posted by hsv-maloo View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VTII Gen3
    Dec 2010
    Default Thanks
    Thanks guys,
    I was after some direction on how to get the trim off but ended up figuring it out.
    Removed the bottom of the rear seat, by pulling the two tabs underneath.
    Then undid the bolts holding the two seat backs in place, and slid the seat back up to remove the seat backs.
    Pulled the centre seat back down.
    Undid all the plastic screws and child seat harness bolt in the parcel tray trim.
    Undid the single plastic screw in the side trim right by the belt tensioners.
    Yanked the trim to free the clips.
    Then could access all the the couple of bolts to undo and remove the whole belt assembly.
    Easy enough job, took the belts out and cleaned them and they work a bit better now.
    The pyro bit on the belt tensioner has "Caution do not remove" in big lettering on it so I decided not to take this apart and lube it up!
  1. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
  2. Air bag and seat belt pre-tensioners light
    By VT1988 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2008, 01:20 AM
  3. seat belt
    By Holden V8 SS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 10:34 PM
  4. Seat Belt Length....
    By dave0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2006, 10:50 PM
  5. Seat belt
    By soyaman in forum Jokes/Humour
    Last Post: 14-01-2006, 01:57 PM
