Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Cameron P
Thread: VX S manual - slow to drop revs
    VX S Commodore Manual
    Jan 2011
    New Zealand
    Default VX S manual - slow to drop revs
    Gudday
    New to the site, i have a 2002 VX S pack manual just turned over 150000kms
    for some reason though, the engine holds its revs in between gears for a short time before dropping. On an early gear change they will even rise to about 2500 before coming down.
    Doesnt seem to do it on down changing so much or when decelerating.
    A free rev in neutral has it hold momentarily before returning to idle speed?
    Can anyone please give me an idea what the cause could be? Many thanks
    VS Acclaim
    Jan 2011
    Queensland
    I would be looking at the TPS (Throttle Positioning Sensor).
    Take it off and give it a clean.. I has a similar problem with an RB 30 one..
    I know its totally different, but may we worth a try.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I'd be giving the throttle a reall go clean.
    Whip it off and give it a good scrub using some Turps in a tub and a nice stiff brush, the getin into the internal bits with an old tooth brush. A little pressure pack is even good to squirt into the small area's you'll be suprised how much crap gets into them.
    If it still does it after that, Start looking for some split vacuum lines.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    is it holding steady revs or just very slowly droping down when you rev it in neutral
    but what you are describing in between gears, i have found all vx v6 manuals do that. sometimes it makes it sound like an auto
    then i jump into my mates vy and the revs drop down like normal
    VX s pac manual
    Nov 2009
    South West Sydney
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    yeah then its every vx manual :P
    because i have cleaned my throttle body about 6 months ago and nothing changed.. but clean your throttle body anyway
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    My VX manual s-pac does the same.. I figured since so much air goes into the engine, it was having a hard time getting it out again so I was considering extractors and shit.. Will this make no difference?
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    nah extractors and SS inductions CAI will make no difference as i have these on my car
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    yep i have the same shit happening with my vx manaul, and its only got 78,000km on it. Ive got a full exhaust. And yes your right ^^^^ it does make it sound like a friging auto. i wish i could fix it to.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    yep, my manual does the same thing. When I got the HD clutch and
    solid flywheel put in it helped a bit but only very slightly.
    None of us are as cruel as All of us. - Anonymous
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    i bought a manual vx so it didnt suond like a shitty auto with an exhaust..
    2002 Vx II Spac Commodore/ 3.6L V6
    Jan 2011
    sydney
    i bought a vx commodore spac manual aswel and it also does the same thing! even when u put it into nutural after being in a gear. the revs will increase a tiny bit and then drop. im thinking maybe holden have done this to make the ride smoother between gears. pitty it makes it sounds more like an auto tho.
  15. #15
    Jan 2011
    New Zealand
    cheers for the help. sounds like a common problem then eh, but ill give the throttle body a clean out. thanks. next step is a bigger exhaust so i can hear the bluddy thing. keen for the same rumble i got from my VR couple years back.
  16. #16
    Vx s
    Oct 2010
    Glenroy
    it shits me to tears. there has to be something to do bout it.
    Now we have moved onto quantum physics and popcorn.
    My vx s
  17. #17
    Jan 2011
    New Zealand
    yep as most you guys said - seems like its here to stay. dammit. cleaned the throttle but no diffrence.
    but before i throw in the towel
    1) qlndhighway - is the throttle positioning sensor the bit in the side of the throttle body with a spring and looks kind of like a schlong? or something else
    2) soop - which lines do i check for splits?
    cheers for any more help. if anyone knows where i can get a downloadable workshop manual that would be mint. cant afford the cash for one here with the way things are going.
  18. #18
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    mate i wouldnt go to great lengths to try and stop this from happening... cause its here to stay lol
    but if you find a cause please let me know :P
  19. #19
    VX s pac manual
    Nov 2009
    South West Sydney
    2003 vy storm v6 ute
    Nov 2011
    Nelson New Zealand
    Hi everyone,my first time on this site.I to have the same problem with revs holding between gear changes on my vy storm ute which is a v6.I spoke to a auto electrical guy about the prob and he suggested unplugging the idle control motor plug to see what happens.So have now been running around for over a week with no real problems.The only difference is the idle speed is approx 2 or 3 hundred revs less when idling.I have also worked out by putting a switch on the power wire to the idle motor it can be turned back on at any time if need be if I plug it back in.The revs between gear changes is now normal.The plug on the idle motor has 4 wires the pale green wire on the outside is the one I put the switch in not the one on the other outside with the black stripe as this one will cause the engine to start revving.
    666
    666 is offline
    vx commodore v6 manual
    Mar 2010
    Hi there,
    I have also got the same problem with my VX I see you also live in nelson
    im going to try disconnect the idle control valve tonight {it drives you nuts aye!!!}
    sounds like it has fixed the prob for you but worries me running it with no idle control
    hopefully we can figure a way to run this correctly.
    Cheers Phill
  22. #22
    666
    666 is offline
    Mar 2010
    Default vx
    Quote Originally Posted by valmet View Post
    hi there Again unplugged the idle control valve yes worked great but!!!!
    mine is now idling at 1400-1500rpm? did yours do this? i unplugged it
    completely did you keep yours wired in some way to keep revs down
    or did you unplug the loom as well?
    vs 5 speed wagon
    Feb 2012
    rosewater
    gday any one no of this problem with vs 5 speed..?spluttre with quick rev and drops slowly when changing gears..any help would be appreciated..
  1. Vn ss revs dont drop when backing off
    By SHIFTKIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-06-2009, 11:38 AM
  2. VY V6 100KM/H Cruising revs MANUAL
    By one_and_only2004 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-04-2009, 04:41 PM
  3. *PRICE DROP*FS: Holden Commodore VT S Manual
    By CHEFAI in forum Vehicles For Sale
    Last Post: 21-01-2008, 12:10 AM
  4. VS Calais revs drop at idling speed
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 01:22 PM
  5. revs drop when dipstick removed
    By VL-VP-VT in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-08-2005, 06:48 PM
Tags for this Thread
