Results 1 to 7 of 7
Thread: How Do I Remove Tailshaft & Replace Uni Joint Rubber Coupling
    Wherry951's Avatar
    Wherry951 is offline PROJECT UNDERWAY
    VT S, V6 5 Speed Manual
    Jun 2009
    Sunshine Coast, QLD - The Defect State
    Default How Do I Remove Tailshaft & Replace Uni Joint Rubber Coupling
    Hey i need urgent help by Friday on how to do this. I have shredded the universal joint rubber coupling at the front, on my VT S Pack manual. Its not the cross looking uni joint by the way
    I bought the new part for $180 today, and i need it fitted for Friday as i have work Friday night.
    The car is currently jacked up and on 4 axel stands. My mechanic has told me all i need to do is undo a few bolts and remove the tail shaft, apparently its that easy, then slot off the old joint and put the new one in and put back together. Just want to check its this easy
    I have also read somewhere the transmission will leak when tail shaft is removed. Will it leak so much i need to replace? And what kind of fluid that leaks will i need to replace, remembering its manual.
    Dont want to stuff it up or anything, so just getting a bit of advice and re-assurance. If anybody knows of any guides to do this on the internet please link me, remembering it is NOT the cross pattern universal joint, its the front rubber coupling. Looks like a big circle/hexagon part with bolts around it
    Thanks
    VT
    Feb 2010
    Wherry951's Avatar
    Jun 2009
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    On the manual, no fluid should leak out. It's only on the Auto where you take the splined part of the shaft out of the extension housing.you'll need to undo the centre bearing bolts aswell, and also at the differential to enable the tailshaft to come completely out. You may need to drop the exhaust down aswell to enable the tailshaft to come out.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    its a great thread
    Quote Originally Posted by Wherry951 View Post
    Yes thats it mate
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Wherry951's Avatar
    Jun 2009
    Did the job myself, took about 5 hours purely coz we had to do it laying under the car, not from the comfort of a hoist. The biggest pain was putting the tailshaft back onto the safety catch braket in the middle near the join from the cat to the exhaust. It kept sitting against the undercarriage of the car and the bolts wouldnt go in. Eventually got it, all works, not bad for somebody non mechanically minded, saved a $120 on labour or something like that so happy with the result
    Also had some fun toying around with the exhaust cut at the diff, and moving it around on the cat abit, but in the end put it back coz low revs sounded like a tractor :P
    VT
    Feb 2010
    Good to hear.
  1. replacing CV joint in tailshaft
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-11-2010, 06:55 PM
  2. Remove rubber mouldings
    By hugh45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2010, 08:32 PM
  3. Rubber joint holding muffler in place
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-05-2008, 05:21 PM
  4. How the remove the tailshaft?-QUICK replys
    By VN_Calais_5speed in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2005, 08:16 PM
  5. Rubber Coupling
    By VZLAD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2005, 08:08 PM
