Results 1 to 7 of 7
Thread: vx r8 troubles help
    vx r8 clubsport
    Jan 2011
    brisbane
    Exclamation vx r8 troubles help
    i have a vx r8 clubsport.never had any problem until 2yr into owning it.we are the 3rd owner and it has only done 158,000km which isnt to bd for its year.last year alone have had to have the radiator replaced fan terminals due to them frying, o2,tail shaft coupling, shockers springs,ignition barrel,gear stick button,rotors back and front,computer over rides due to false reading of leaning on left and right of engine, bushes replaced drivers side front n back and tri rod z bar also.now ive been told that now the sterring rack is needing replacing also due to excessive movement.
    unknown problem of wearing on passenger front tyre on the inside aswell as brakes ont hat side wearing down quicker than the drivers side.
    to top it off now there is a crunching noise coming from the drivers side front when puchin in the break peddal.does anyone know of why it is doing this?
    please help as in the past yr n half have spent $6,000 not including rego butincluding services and tyre yet everytime the car goes in another problem is found.
    its very frustrating and at the moment i really dont want to spend anymore money than i have 2 on it
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Sounds like it has had a hard life an now unfortunately your paying for it.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    vx r8 clubsport
    Jan 2011
    brisbane
    yeah seems that way.drive it normally though nothing stupid or anything.keep being told by the mechanic that its normal for its age but i havent heard of anyone having to have so much done to it in such a short time.
    its a lovely car but frustrating as hell
    vx r8 clubsport
    Jan 2011
    brisbane
    any ideas on the crunching noise though when breaking?its only when u push in the peddal hard
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    maybe a rock stuck in between the rotor an pad or no pad left at all an its metal on metal.
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by bubz clubbyr8 View Post
    sounds like all the parts you have replaced are the original parts that came with the car an having that many ks they have held up well but now that you have repalced them shouldnt have to worry about them for another 100,000kms not really much you can do mate either sell it or keep replacing the parts as they break by the sounds of it you dont have much left to fix.
    EDIT:But if you keep it serviced from now on you shouldnt have many more troubles with it .
    vx r8 clubsport
    Jan 2011
    brisbane
    it has new brake pads and rotors neither are worn down.we found out it has the harrop performance brakes etc.noise only start with breaks after suspension was changed.it now has slotted 343mm rotors ont he front it used 2 have drilled.mayb there isnt enough ventilation and thats y the breaks still scream when it is hot???
  1. Troubles with my VK
    By Dazza_Bo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2010, 04:02 PM
  2. having ecu troubles??
    By Haydz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2009, 03:05 PM
  3. VL troubles
    By maxpower QLD in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2008, 07:27 PM
  4. key troubles
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2008, 12:45 PM
  5. sub box troubles HELP please
    By mistervr94v6 in forum Car Audio
    Last Post: 04-09-2005, 06:56 PM
