Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Cooling System (Pellets)
    VU S2
    Jan 2011
    Default Cooling System (Pellets)
    Hi All,
    I'm new here and new to owning a VU series 2, 3.8 ute in the last week.
    Given that it hasn't been serviced in a while I flushed the cooling system today and had bought the pellets to go in also, but forgot to add them.
    Is it safe enough to crush them and just add them from the radiator lid rather than the hose seeing as i've now filled the system?
    Scott
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    yep you can as long as you crush them alot before you put them in , pressurize the system (as you would if you were bleeding the system then let it cool and make sure the pellets have circulated also make sure its a 50/50 coolant mix thats very important otherwise it will overheat and cause all sorts of problems... (pre mixed is only 33% UNLESS specified)
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VU S2
    Jan 2011
    Quote Originally Posted by fitz_vt View Post
    Thanks heaps guys, I used the genuine Holden coolant 50/50 so that's all good, I was just kicking myself that I paid for the pellets and forgot to put them in after all that.
    Appreciate the replies.
    VT
    Feb 2010
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by ])R@G()N View Post
    Do you really need them anyway ?? what do they do?
    You dont have to but, is reccomended you should use them, it stops corrosion happening in the radiator, its cheaper to buy the pellets then a new radiator.
    I normaly just put them in under the radiator cap ive never had a problem before, crushing them up makes more sense tho.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VT
    Feb 2010
    I just put a new radiator in yesterday. I've only put coolant in it.
    One of tanks on the old one slit luckily I wasn't to far from home.
    VU S2
    Jan 2011
    I thought that also, but it states it in the book and for the $7 from memory, I didn't complain.
    On another note, I noticed there is coolant that has run under the surge tank since flushing, would this be as a result of filling too much coolant?
    VT
    Feb 2010
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Not many people worry about adding the pellets. I have never used them.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    for the small price they are why wouldnt you?
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by MR_VX View Post
    I know a lot of people wont use them because they seem to "crud up" the cooling system after a while,and they make the coolant look dirty/rusty.I dont use them.I do use castrol coolant that is specifically made for the commodore V6 engine though...
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    the castrol anti freeze 350? i searched hi and low for it but couldnt find it anywhere.
    vs commodore
    Oct 2009
    Tamworth NSW
    I threw the bottles ages ago,so im not 100% sure,but it might have been called something like "350" actually,but I know it says on the front of the bottle that its specifically made for the commodore/toyota lexan V6 engine.It cost around $45 for 5 litres.I got it from supercheap.I was using a few different coolant brands, except for the cheap stuff, before I spotted the castrol one specifically made for the V6 engine,so I thought Id try it out,and have been using it for a while now.Ive done two coolant changes with it.
  15. #15
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Brett_jjj View Post
    true true it does make it look rusty. I only use them because Holden recommended me to use them thats all. Ive never thought about it to "crub up" the system but i can see ur point there.
  16. #16
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Umm... the pellets were for lubricating seals not corrosion inhibitor arn`t they after 1997 type b coolant has lube added to it in which case pellets are obsolete from what I know.
  17. #17
    fitz_vt's Avatar
    Nov 2008
    The Pellets are to A. Extend the life of your coolant and B. Lubricate Seals.
    Always use a coolant that complies with the HN2043 Specifications usually castrol 350, nulon long life coolant .
    There is three types of coolant
    (TYPE A)Ethylene Glycol (mono ethylene glycol to be exact). In concentrate form is does come from some manufacturers quoted as grams per litre concentrate, but under AS/NZS 2018.1, 1998 Type A (from memory), to pass standard it must have at least 95% ethylene glycol, by volume, the rest is usually a corrosion package. This type of coolant is an anti freeze-anti boil and commonly referred to as Type A concentrate.
    Type B is Radiator corrosion inhibitor ... this is as it says, no ethylene glycol to speak of, even if the 200 ml cans says it has some, by the time you mix at the recommended treat rate of 5%, there is not enough glycol to make a difference to boiling and freezing points.
    3. this is the more recent type of coolant known as OAT (organic acid technology) and is becoming more common in new vehicles, and is usually not compatable with ethylene glycol coolants. (red coolant dont use this in your commodore......)
    Type A coolants can be diluted as per OEM (vehicle) requirements, usually from 33% glycol to 50% glycol in demin or distilled water.
    Type B coolants are not anti freeze-anti boil, but straight corrosion inhibitors.
  18. #18
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by undar8ed1 View Post
    So would you use it in nulon long life coolant, it lasts five years any way so the pellet would still be obsolete right?
  19. #19
    fitz_vt's Avatar
    Nov 2008
    Pretty Much most of them come with the lubricant in them.
  20. #20
    VT
    Feb 2010
    After taking the side tank of my old radiator I will not use Pellets ever again. All they are good for is blocking your radiator up
  21. #21
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    They sound a bit like "Stop leak", block every cavity within your cooling system, except the hole that you put it in to block...............
  22. #22
    vx v6 comodore
    Jan 2011
    sunshine coast
    i went to buy some of them pellets from holden the other week and they said they dont sell them any more because they aparently change the colour of newer coolants or something along them lines..went to holden in maroochydore qld.. can u get them from other stores like autobarn,repco ect ??
  23. #23
    VT
    Feb 2010
    Quote Originally Posted by VYMAD View Post
    Check this out
    I had 150mm's of radiator working that must be all I needed because it never got hot.
  24. #24
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Holy crap! Is that just from using pellets?? Glad I have never used them. I seem to remember reading somewhere that Holden don't use them anymore either. If that's right then I can see why.
  25. #25
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Dont use pellets.
    With decent quality coolant and a sealed cooling system that wont allow air in, they arent neccessary.
    Silver Certified.
  1. Air in cooling system
    By quombone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2009, 05:45 PM
  2. My Cooling System... Help
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 09:03 PM
  3. V6 Cooling System
    By tja_bot in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-03-2007, 01:27 PM
  4. Cooling system pellets
    By Lloyd1986 in forum General
    Last Post: 15-02-2007, 12:30 PM
  5. Oil in the cooling system?
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2004, 11:43 PM
