Results 1 to 6 of 6
Thread: Engine only running on 4 Cylinders
    M5.
    M5. is offline
    VX S (5 speed)
    Jan 2011
    Geilston Bay
    Default Engine only running on 4 Cylinders
    Half through a 200km trip the VX dropped cyl 3&6 (no spark). Stopped at the servo natually I offed free advice by another commodore driver who said one of the coil packs had packed it in. I'v swapped over the coil packs, but 3&6 still have no spark.
    HELP???
    Benny
    got the Commodore home 200km ok on 4 cyls.
    '98 VT Exec Manual
    Nov 2008
    Albury
    Hey mate I had the same problem in my VT, it was the coil pack also however I need the entire ignition module replaced (its basically the base plate that all the coil packs run off)
    Hope that helps
    VT
    Feb 2010
    Yeah same thing happen to my one (ignition module) 2 days after I got it, lucky it was under warranty. that was 10 years agon and hasn't done it again
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above, i'd be checking your dfi module. Also give it an oil change asap as your sump will be full of unburnt fuel which has contaminated your oil.
    VP Exec
    Jun 2005
    Maybe check the 'plugs and leads too; one cylinder not firing will kill it's paired cylinder also.
    vt s pack
    Oct 2010
    brisbane
    get ur dfi from a wreckers.... $65 here with 3 coils..
    holden wanted like 600+ and 200+ for dif mod and each coil..
  1. Vr V6 Running on 5 Cylinders
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2009, 04:14 PM
  2. vs running on 4 cylinders
    By zx7rtas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 05:59 AM
  3. VN S1 only running on 4 cylinders
    By norman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2009, 12:55 PM
  4. Running on 5 cylinders.
    By J_D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 07:03 PM
  5. Not running all Cylinders
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2007, 07:59 PM
