Results 1 to 8 of 8
Thread: drivers side wont lock anymore:S
    2010 Holden VE SIDI SV6
    May 2009
    Default drivers side wont lock anymore:S
    hey all,
    need help drivers side door wont lock anymore, i have to use the key to turn and lock it now, any ideas cause all the others still lock and unlock fine
    cheers
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    sounds like a faulty door lock actuator as the key will manually lock and unlock the drivers side door
    fairly simple to replace.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    May 2009
    fitz_vt's Avatar
    Nov 2008
    Good question on how much it costs holden should be able to direct that enquiry.
    a gregories or holden service manual comes in a little handy for this next part
    removal i think is the following ....
    power windows miss following step.
    wind down window.
    Manual windows from memory there's a clip you've gotta remove before taking the handle off the door. (carefully pry the handle towards drivers seat and then using a hook remove the retaining clip)
    remove lock buttons by inserting a sharp pointy tool into the centre of the orange button insert and carefully prise the insert from the button. slide the button off the control rod (the gregories manual says you might want to get a new one incase that one is damaged upon removal) remove the outer guide for this button using a screw driver.
    Remove the door handle as follows remove screw from centre of door handle partially remove door handle then remove retaining clip from control rod at the rear of the handle and then remove the control rod from the handle and then the handle from the door.
    remove the trim cover next to the mirror remove the mirror retaining screws and withdraw the panel.
    remove the door trim panel by removing the screws from the bottom and sides of the door card. gently remove the bottom of the door panel lifting while you remove it then disconnect the power mirrors switch and then carefully remove the trim from the door then remove the panel
    remove the two phillips head screws holding it in place remove the wiring loom from the old one plug the new one in screw the actuator back onto the door then test.
    reattach door panel and your done
    ** just a note i take no responsibility for damages or false procedure to remove door panels this is advisory only it is recomended that you seek a workshop manual or an auto electrician.**
    keeny's Avatar
    keeny is offline keeny
    vz calais alloytec 190
    Dec 2008
    Maitland, NSW
    if the lock does pop up but not all the way it may just need some wd 40 on the actuator and mechanism, Have heard it it quite common that they get dirt build up and become sticky, however if the lock doenst pop up at all than that sounds like the actuator itself.
    May 2009
    vx s pack II
    Jan 2010
    aLKIDA
    Test for power first dont just go changing parts. Because if there is no power and you change the actuator it wont work.
    If there is power then the unit is faulty.
    It could be a open circuit in the wire i had one at work. The problem was were the wire runs into the door covered with rubber there was a tiny break in the wire. Because the door always opens and closes.
    VX Clubsport
    Feb 2011
    Thats a common prob mate i have done a few in my time on vt,,vx,vz,and vy's just get one from a wrecker about $100 i think for a new one from holden is a bit expensive
    you could put the one from the other side to double check but i would say you will have to replace it
  1. Drivers Side Door Lock
    By nstone63 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2010, 12:54 PM
  2. Drivers Side Door Lock
    Last Post: 03-05-2010, 12:25 PM
  3. VS Front drivers side door lock removal
    By Kev_VSVZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2009, 09:59 PM
  4. Replacing Tail Light and Drivers Side Door Lock and Latch
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2009, 12:35 PM
  5. door lock button - drivers side
    By barny in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 06:12 PM
