Results 1 to 2 of 2
Thread: steering rack probs
    VX Clubsport
    Feb 2011
    Default steering rack probs
    Hey all i just replaced a steering rack in my 2001 vx clubsport (2nd hand) really wired, after the car has been at operating temp for about 45 min so about 1 hour of driving the pump starts getting a bit nosier like it needs to be bled. Then leave it over night start it and back to being quiet then it happens again.
    No leaks and no loss of power
    Just wondering if there is a slightly different version i might have cheers
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Noise in Power Steering
    1. Looe or defective drive belt
    2. Air In Hydraulic System Bleed system (as described below)
    3. Loose or incorrectly installed powersteering lines tighten or correctly install power steeing lines
    4. Loose pump mounting bolts or braket instpect for damage and renew if necessary
    to bleeed the system you.
    1. check and top up fluid if necessary.
    2. raise the vehicle on jack stands
    3.with the engine turned OFF turn the steering rack from lock to lock serveral times top up as some air may come out repeat until fluid level no longer drops
    4. start the engine and repeat the process of lock to lock contacting the lock stops lightly
    5. when no more air bubbles appear in the fluid reservoir and the fluid level remains constant the system can be considered bled.
    6. make sure your wheels are straight and lower the vehicle to the ground
    Hope this helps.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
LinkBacks (?)
  1. 21-06-2011, 07:50 AM
  1. Swap variable speed steering rack for regular rack?
    By _R_J_K_ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2010, 08:06 PM
  2. [VIC] WTB VN steering rack
    By Shortstuff in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2009, 08:32 PM
  3. VQ steering rack into VK
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-07-2009, 09:59 AM
  4. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  5. Steering rack probs...
    By Alan Shore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2006, 02:55 AM
