Results 1 to 11 of 11
Thread: stalling at idle
    psycho_smurf's Avatar
    psycho_smurf is offline Donating Member
    2004 VZ Executive
    Aug 2010
    Rockhampton
    Default stalling at idle
    It never rains it pours... if anyone could point me in the right direction I'd be ever so grateful.
    This morning the old VT (automatic) wouldn't start, she'd crank over and almost kick in then die immediately. I checked all the fuses and relays, and all were fine. A few hours later I tried to start her and she fired up as per normal.
    I took her for a drive tonight, and the power train light came on. On the first corner as soon as I let off the accelerator, she stalled. Doing 40-ish around a bend and suddenly losing your power steering and brake booster was poopy. So, now every time that it should return to idle, like stopping at lights or slowing right down, etc, it cuts out. Lights etc keep working, and she will fire up again no worries, but I have to drive around with a foot on the brake and one on the revs to keep it above 1000rpm or it dies.
    On an unrelated matter, my internet wont let me access any search engines, its my kids first day at daycare tomorrow and I have to be at court at 9:15am.
    vs commodore
    Oct 2009
    Tamworth NSW
    Have you tried doing an error code check to see if any error codes have logged? Thats where Id start.It might point you to what is wrong.
    D22 St-r Navara
    Dec 2010
    perth
    VT Acclaim Wagon
    Oct 2008
    'n check every vacuum hose you can find especially around the back of the motor. VT is up to 14 years old now and rubber just don't last that long. Tyre people tell me that 5 years is about the usable life of rubber. My VT is the first one (1997) and the hoses have already been replaced by previous owner. I am going to be doing them again soon as the main throttle body air hose is showing signs of needing it, (little cracks etc)
    2004 VZ Executive
    Aug 2010
    Rockhampton
    Hey thanks for the replies, I've checked the error messages and it states error 48 "Cam angle sensor (no signal)". Thank god for you guys, I had never even heard of this error code system. As soon as this cyclone rain buggers off, I've got some repairing to do...
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive had a problem before with the same error code a couple of years back on my VS ecotec.I thought it was the cam angle sensor was just faulty,but what had happened was,the cam angle sensor pickup magnet, that is located in the camshaft sprocket, had moved forward in its locating hole on the sprocket, and it had hit the sensor which smashed the magnet.I had to remove the timing cover to find and remove the pieces of old broken magnet,and to fit the new magnet.The pickup magnet comes in a plastic cage thing that holds it in the camshaft sprocket.Ive since read that in the USA ,quite a few people have had this happen with these engines,and they actually glue the magnet into the camshaft sprocket hole so it cant move.If Id known about this before I replaced mine,I would have glued it in too.Anyway,hopefully your problem is just a broken wire or bad connection,or even a faulty sensor.I reckon that you would have to be unlucky for this to be your problem,but keep in mind,it can happen.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    Just be carefull it could also be your DFI moduel under your coil pack the signal relays through this as well and could give you the same code
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    cam angle sensor only controls the sequential injection, so when it fails, it'll still run fine. A dodgey crank angle sensor can throw up the same code.( they run off the same circuit.)
    2000 vt
    Jan 2011
    hunter valley
    ok this is your torque converter stuffing up take it to a transmission specialist and they will fix it for you
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by 97bermudacalais View Post
    When my cam angle sensor pickup magnet got broken,the car ran like a bag of shit,it kept stalling at the lights and generally running heaps rough.Theres no way Id say it runs "fine" without it.
    Once I fitted the new pickup magnet,she was all good again,back to running normal.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    did any error codes pop up? if so list them and we can all help you from there
    Quote Originally Posted by psycho_smurf View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. V6 Auto almost stalling at idle
    By Defected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2010, 12:36 AM
  2. VN Surging Idle Stalling
    By franklinfrog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2010, 11:31 PM
  3. vn stalling at idle
    By vnv6 wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2010, 01:24 AM
  4. VL Stalling on warm idle
    By kirsty_y81 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-03-2010, 09:07 PM
  5. VN V6 S1 is stalling at idle
    By Pav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2008, 11:40 PM
