Hey guys,
On my VX when i turn my head unit on, my antenna also extends to full reach.
I know this is normal, thats not the problem.
I only ever use my AUX port, never the radio, and look like a spack driving round with my antenna up blasting out non-mainstream music.
Is there any way that I can stop the antenna from extending myself? Or is it an auto-elec's job?
Just add a switch to the power wire.
Ronald Reagan (1986)
yehh i had the same problem, i just removed the inner guard and then theres a plug that will have a red + white wire going into it, just unclip that plug and problem is solved
Dont murder the newbie,
But where and what is the inner guard exactly? Never heard of it.
Just splice into the wiring and add a on/off toggle switch , splice into the positive +
so when you dont want to to go up when you have the car on switch to off then when you want to turn it on etc
the white wire controls the up/down function +ve it goes up remove the +ve it goes down
hope it helps
THe inner guard is that big black plastic thingy that fits around the inside of the guard . If you undo the screws that hold it on ( just the ones near the antenna ) and pull it back ,you will see the antenna motor and the wires
i just wired up a swith so it goes up when i want it to. just use a flat rocker switch so it looks better
i do as the voices tell me
