Results 1 to 3 of 3
Thread: Climate control vacuum solenoid pack repair
    vx II r8
    Dec 2006
    Default Climate control vacuum solenoid pack repair
    My vt calais had the a/c vents changing around when accelerating fault.I checked out the vacuum
    solenoid pack under the passanger dash.I removed it from its black case,and after rehooking up the
    vacuum hose and plug found that twisting /touching the board made 3 of the solenoids click in and out
    by themself.On closer inspection of the back of the circuit board i found that some of the solder joints
    had small cracks around the pins,causing a bad connection.I then resoldered the affected pins on the
    board.While i had the solenoid pack out,i uncliped the plastic vacuum hose connection on the top of
    each solenoid and removed the metal valve and spring inside.I then cleaned out the hole/sealing area with some compressed air(it had small particles of rubber from the seal on the end of the metal valve).Then i put everything back together and tested it.It fix the fault !
    If you dont want to pay $150+ for a new solenoid unit,this would be worth a try.
    I would say the circuit board doesn't like the constant heating and cooling effect it gets from being
    connected the the fan box over time causing these small cracks to form in the soilder on the
    board.And the rubber dust particles on the sealing area of the valve inside the solenoid wouldn't help either.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Top work hey
    and 3 Dangerous non ABS VN's
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Goood idea
    Quote Originally Posted by james34 View Post
    my vt calais had the a/c vents changing around when accelerating fault.i checked out the vacuum
    solenoid pack under the passanger dash.i removed it from its black case,and after rehooking up the
    by themself.on closer inspection of the back of the circuit board i found that some of the solder joints
    had small cracks around the pins,causing a bad connection.i then resoldered the affected pins on the
    board.while i had the solenoid pack out,i uncliped the plastic vacuum hose connection on the top of
    each solenoid and removed the metal valve and spring inside.i then cleaned out the hole/sealing area with some compressed air(it had small particles of rubber from the seal on the end of the metal valve).then i put everything back together and tested it.it fix the fault !
    board.and the rubber dust particles on the sealing area of the valve inside the solenoid wouldn't help either.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. VT Climate Control (Vacuum??) Problem?
    By Zeussy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2011, 07:30 PM
  2. Climate Control Vacuum Probs VY Calais
    By oztech007 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-09-2011, 06:52 PM
  3. Climate control unit losing vacuum ?
    By Fletch_QLD in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-02-2011, 07:40 AM
  4. VT climate control fault (vacuum?)
    By tom26 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2010, 05:39 PM
  5. VYII Climate control vacuum leak help
    By BERVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-10-2008, 09:53 PM
Tags for this Thread
