Results 1 to 17 of 17
Thread: metho in the fuel tank to get rid of any water?
    vx ss
    Jan 2011
    whittlesea
    Default metho in the fuel tank to get rid of any water?
    Hi, sorry if this is a silly post but im new to commodores i just got a s2 vx ss manual with 145000km on the clock.
    i noticed when i went and first had a look at the car is was low on fuel, and when i pickd the car up it was low on fuel so im guessing they used to run it fairly low most of the time!
    As you know if it is low on fuel on cold nights it would build up condensation in the tank! i was told metho will help the condensation burn if there is any in the tank? is it safe or should i not even worry? i have only had the car 2 weeks, love the car
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    i know the oldman does this in his boat dont see why it wouldnt work in the car.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    I poured about 250ml into 1/4 tank the other week, car still runs, its safe
    ________________________________________
    vx ss
    Jan 2011
    whittlesea
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I used to do this after my old HR was sitting for long periods of time, never hurt it but that was a old motor.
    Best RPG ever
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vx custom 600RR
    Oct 2010
    it's perfectly safe
    the theory behind it is that water wont mix with petrol but will with metho and that metho will mix with petrol
    Nov 2008
    Smithton, Tasmania.
    Metho displaces the water, or absorbs it.
    It doesn't really mix with the fuel but it will burn, unlike water.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    The tank wont rust!....... The fuel filter will catch any water droplets that get that far, so change the filter, then cut open the old one, then any water in the system will be evident. That'l put your mind to rest, ..........................to rest before you come up with something else to worry about...LOL
    Metho in the tank is an old bushys trick, to get rid of moisture in fuel thats pumped from outback suppliers dubious tanks.
    VP Exec
    Jun 2005
    I don't think that you should even worry. If it's really a concern to you simply run a few tanks of E10 through it and change the fuel filter. "Metho" is just denatured ethanol anyway and I'm not sure that all the water is removed from it (unlike the ethanol used in E10).
    psycho_smurf's Avatar
    psycho_smurf is offline Donating Member
    2004 VZ Executive
    Aug 2010
    Rockhampton
    Yeah I did that years ago with my jag after going through one of those automatic car washes, as the jag had the fuel caps up above the boot lid. Worked a treat
    VT Acclaim Wagon
    Oct 2008
    I'm with Cheap6, if you put a tankfull of e10 through, @10% alcohol you are getting 7 liters of alcohol (metho) in the tank. If alcohol absorbs water, I think 7 liters of alcohol would do the trick very well. Then remember to keep a decent amount of fuel in the tank all the time. If you can afford to at todays prices.
    1994 HSV CLUBSPORT NO.356
    Mar 2009
    wainuiomata new zealand
    isopropyl alcohol is meant to work good for getting rid of water also,goodluck
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    and you cant get it at the chemist
    Quote Originally Posted by 94CLUBBY View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  15. #15
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    metho is a old timers trick. it works. so stick with it. plastic fuel tank=no rust pablo, your fuel filter will only hold so much water, then it just flows straight through
  16. #16
    Mar 2009
    [QUOTE=justbad4you;1769500]and you cant get it at the chemist[/QUOTman you must have some chemist where you come from ha ha
  17. #17
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i did it with a 253v8 hz and it blocked the fuel filtter
  1. Think i got water in fuel tank
    By calais_cruzin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2011, 12:03 PM
  2. Water Tank Pressure
    By sadler91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2009, 02:40 PM
  3. [SA] wtb - radiator water tank for vn s1
    By Pimpn1 in forum Swap / Wanted to Buy / Trade
    Last Post: 13-01-2009, 12:39 PM
  4. how to remove Water in fuel Tank
    By Lafanter in forum General
    Last Post: 22-04-2008, 09:06 PM
  5. HELP Metho in fuel?????
    By SexGod in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2006, 12:40 PM
