Results 1 to 6 of 6
Thread: Window gets stuck when winding up!
    VX Executive Wagon
    May 2009
    Default Window gets stuck when winding up!
    I have a problem with the drivers side window in my VX. It is a manual wind up type. You can wind the window down easily but when you wind it up, it gets stuck every 360 rotation of the handle. If you wind the handle backwards a little, you can get another 360 rotation before it gets stuck and repeat this until it gets to the top.
    What needs to be replaced to fix the issue?
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    your window reg needs replacing. Some times it is just a small plastic runner brakes can be fixed for verry littel in this case.
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    haha exactly the same problem I had. I just got really angry at it one night
    and punched the door real hard, haven't had a problem since
    None of us are as cruel as All of us. - Anonymous
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I had a similar issue in my VP. The rubber that the front edge of the glass sits in had split inside the door and the glass was getting caught in it as it went up. I just cut the split bit off (it's just a work hack) and it's never done it again. Got an occasional rattle when the windows down now though...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VX 2001
    Feb 2011
    Lightbulb I have same problem
    Vx
    took the door apart had a look at the mechanism. i could not find a way to fix it. the problem is in the winder area. I think the teeth in the cog have something to do with it?
    I wd40'd it and put in back together. The WD40 did help some...
    Did ya get yours fixed?
  1. drivers window stuck???
    By mahe09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2009, 07:57 AM
  2. window scratches made while winding window
    By callum_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2009, 08:30 PM
  3. Power Window Stuck
    By 90TTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2009, 12:56 AM
  4. removing/replacing window winding mechanism?
    By Victimiza in forum General
    Last Post: 21-02-2008, 11:08 PM
  5. VS Acclaim - Window Winding Issue
    By hightekhosting in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 01:52 AM
