Results 1 to 8 of 8
Thread: SS wont start
    VT SS S2 Gen3 and VZ Exec.
    Jan 2011
    Default SS wont start
    Hey guys anyone seen this before? My VT S2 SS gen 3 does this thing very occasionally where its like its not in park or neutral when i try to start, the dash lights up but the starter is dead, it did it once before it took me an hour of trying then it just started, right now ive been trying for hours no luck. Any ideas would be much appreciated. Cheers
    VT Acclaim Wagon
    Oct 2008
    Not sure if same as my problem but I cleaned the contact spring around the ignition keyhole plus the little knob sticking out of the keyhead and my son suggested that I change the way I put the key in. The key head has little knobbly bits in a depression on one side. That side has to face down, he says (he worked for a very big holden dealer in Brisbane). Well after the clean and change in the way I use the key, I have not had the problem since. Do all your dash lights come on? Have you checked all your battery cable terminals for clean, bright contact surfaces? Both at the battery and the other ends of the cables. The little wire to the starter motor solenoid can be corroded or insecure as well. That enough to go on with for now?
    Jan 2011
    Yeah everything seems normal except nothing when i turn the key to fire up the engine, ive checked all the obvious things, battery connections etc, its like its in gear but its not, ill check those contacts thanks for that, Im thinking its that or immobiliser or inhibitor switch.
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    Try moving the shifter back and forth or ever try locking and unlocking the car with the remote.. Maybe something simple..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by DVOLVO View Post
    Agree, with DVOLVO, same thing happened with mine. Try unlocking the car with the key in the ignition, try turning it over in N and P or perhaps in drive- then in park. Everything like that, the older they get the more twitchy the twitchy electrics in a VT get.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Yes as said above your BCM/immobiliser is most likely the culprit, though cleaning the neg terminal on the battery would not hurt
    Take off the neg post clamp and snip the cable back a 1cm or 2 (till its nice clean wire) clean the clamp with a wire brush/or replace with a newy and replace the clamp on the wire.
    Jan 2011
    Ok well after hours of trying to solve it checking inhibitor, connections, battery, etc it finally just started like nothing was ever wrong, i was messing about with the key in the ignition when it came right so maybe its a prob in there? Will tidy up battery terminals as advised though cheers for the advice all
    VT Acclaim Wagon
    Oct 2008
    You may have just had some crud on the little contact outside the ignition barrel
LinkBacks (?)
  1. 27-06-2011, 02:20 PM
  1. HELP! VX com wont start
    By Palmz17 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2010, 05:16 PM
  2. just wont start
    By apprentice backyarder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2009, 11:56 AM
  3. vn wont start
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2009, 06:56 PM
  4. car wont start
    By urmyho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2006, 08:31 AM
  5. vn v6 wont start
    By prince_dj666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2005, 01:19 PM
