Results 1 to 6 of 6
Thread: Downsides to LPG Dual Fuel?
    1998 VT S
    Feb 2011
    Port Macquarie
    Default Downsides to LPG Dual Fuel?
    Hi guys
    Going to be getting a new car in a month or so and I'm pretty set on a commodore. My budgets around 7ish. Anyway I've found a great looking 98 VT S which already has a lot of the modifications that I would have been making to it anyway, but its also got an LPG Dual Fuel system.
    I'm not very experienced with Dual Fuel. I've spoken to the guy and he seems pretty genuine, says the Dual Fuel system is setup properly and the engine is mechanically sound, runs great on both gas and fuel.
    So my two questions are:
    1. How does running on Gas compare to running on Fuel in terms of performance? Does it lose some grunt? Splutter? Anything like that.
    2. Even if I ran it purely on Fuel, would it run like a normal car on fuel? Or would it be effected by the presence of the LPG system.
    I apologize for my lack of terminology, I'm not overly car savvy And I also did try and search this, but couldn't find the answers I was looking for.
    Any info/advice is much appreciated, thanks guys!
    MkyHnly's Avatar
    MkyHnly is offline Finally enjoying my P's!
    VT S Pack - VC SL/E 253
    Jun 2009
    Croydon, VIC
    it all depends on how it was ORIGINALLY set up as to how the car will run... depending on the type of system and set up, you normally lose a bit of power but nothing to be overly concerned about unless you wanna race people...
    and how the car was tuned depends on whether it runs well on gas, or runs well on petrol, or has a 50/50. some are tuned to run better on gas but others splutter when they try to start on gas and stuff. you normally dont have issues with the factory set-ups, but like i said, there are plenty of variables when it comes to dual fuel.
    cheers
    1998 VT S
    Feb 2011
    Port Macquarie
    Hmm ok. I guess the only way to be sure would be to take the guys word on it and test drive it myself. Problem is its a good 3 and a half hours from where I live :P
    Anyway, cheers mate.
    Vt Clubsport
    May 2009
    Mmm well if it's daily v6 I'd convert it, if you plan on power mods then don't. If you gave LPG it requires alot if servicing and tuning. If you don't do it properly say goodbye to injectors etc. Just be careful if u get it make sure you take care of the setup and have it tuned regularly, be sure to drive petrol frequently too so u don't kill your standard injectors gl
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    VT Acclaim Wagon
    Oct 2008
    I am disagreeing on LPG being harsh on motors. My brother owned his own taxi which ran exclusively on LPG. The engine was still running well at 500000Ks when he sold it. He also was the radio operator for a taxi company and knew many other cab owners who also had High k motors and swore by LPG. It is not just cheaper fuel but it wears the motors much less than petrol. You only have to look at the oil in the two different motors. LPG motors run much cleaner oil (less carbon abrasives) and the oil looks clean from change to change. Engines run on petrol have black oil after only a 1000Ks. More carbon and diluted oil (with petrol getting past the rings). don't believe me? Take your city car on petrol for a 200Ks high speed run on any highway and check your oil level after that. It will be down on the dipstick. petrol, water and acids burned off through the PCV. does not happen with LPG motors. By the way, if you can afford it, LPG liquid injection is the go. imperceptible difference in power between it and petrol. Another long post. Ah well, got to explain what I mean.
  1. dual fuel
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2009, 09:51 AM
  2. 98 vs v8 ute dual fuel!!! EC
    By LethalVS in forum Vehicles For Sale
    Last Post: 06-02-2007, 08:58 PM
  3. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
  4. whats the downsides
    By Spilly in forum General
    Last Post: 01-07-2005, 10:16 AM
  5. downsides
    By Spilly in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-06-2005, 02:34 PM
