Results 1 to 2 of 2
Thread: VT rear middle seat, removing plastic bit?
    VT Berlina
    Jan 2011
    Bundoora, Vic
    Default VT rear middle seat, removing plastic bit?
    Is it possible to remove the plastic piece (with the cup holders) that is on the rear middle seat or is it welded in?
    Thanks a lot, Michael.
    VT V8 Calais
    Mar 2007
    Hey Michael
    To remove that part of the seat, remove the bottom part first (there are tabs that you pull forward at the base of the seat in the foot well.
    Then you will see a bolt at the bottom of the right and left hand sections of the seat, remove these and slide both sections out.
    Now take a look at the cup holder bit, there are 4 bolts you will need to remove and the center section lifts straight out.
    Hope that helps
    50LTRv8
  1. [VIC] Wtb: Wh statesman - rear middle head rest and/or centre seat
    By tigass in forum Swap / Wanted to Buy / Trade
    Last Post: 16-06-2010, 08:18 PM
  2. rear middle seat belt stuck
    By melodee09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2010, 09:13 PM
  3. Vt wagon rear middle seat belt???????????????????????
    By 11gothevt11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2010, 11:36 PM
  4. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
  5. Removing middle back seat
    By Fitty5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2008, 07:27 PM
