Results 1 to 7 of 7
Thread: Power Steering whining when turning?
    1998 VT
    Sep 2010
    Default Power Steering whining when turning?
    Hey guys
    I have a 98 VT Exec, and everytime i start it up and well, turn, the car starts to make a whining noise
    I think it may be the power steering belt or the fact that my power steering fluids are low-ish
    How can i get it fixed and how urgent is it ?
    Cheers GUYS!
    VR Commodore, VK EFI 5.0 Calais
    Nov 2010
    Mount Gambier
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dobes View Post
    Hey guys
    Cheers GUYS!
    Top up the power steering fluid.
    MY RIDE
    2002 VX Equipe S2
    Jan 2011
    Bunbury, WA
    Has it been lowered? A mate of mine lowered his VS ute but kept the stock struts and it 'whines' a little when turning.
    vs commodore
    Oct 2009
    Tamworth NSW
    On the VS models ,if the steering makes a groaning,moaning type sound when the steering wheel is turned,the cause of this noise is the bush where the steering column goes through the firewall.To fix it,all you need to do is spray WD-40 up into this area where the bush is,from the engine bay side.After being told my steering rack and pump were stuffed and causing this noise,I read about this fix on here, and thought Id give it a try,it fixed it instantly,and 2 years later after spraying it with WD,the noise still hasnt come back.Im not sure if the VT has this same problem with this bush or not.Ive fixed quite a few VS's now with this noisy steering problem using WD.
    psycho_smurf's Avatar
    psycho_smurf is offline Donating Member
    2004 VZ Executive
    Aug 2010
    Rockhampton
    VT's are known for their dodgy seals in the power steering pump. You can buy new seals for like $12, but you'll need one of those bearing press machines to do it yourself (apparently). I wouldn't say it's *very* urgent, it'll just start leaking more and more. I just top mine up every few weeks until I can afford a new one. Been doing that for 4 months now...
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Mine does the "whining" too, the fluids are fine. A few people on this site reckon it's the pump as I don't have power steering unless I rev the engine. I really need to get that fixed, though I debate it- if I keep trying to park it I'm gonna get ripped :P
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
  1. vy v2 power steering pulsation on turning
    By ronthetruckie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-02-2010, 06:36 PM
  2. Whining power steering
    By Calaber in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-06-2009, 10:35 PM
  3. Power Steering Noise when turning right
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2008, 10:40 PM
  4. noisey power steering when turning right
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 01:14 AM
  5. Squeaking/Whining Steering Wheel
    By orchie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2006, 06:34 PM
