Results 1 to 3 of 3
Thread: VT Berlina 250K service
    VT II Berlina
    Aug 2009
    Hampton Park, VIC
    Default VT Berlina 250K service
    Hi,
    I have a 2000 VT II Berlina that's approaching 250 thousand kms. Is this going to be a major service? Also, any faults I should start looking out for?
    cheers,
    Tim
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Well When was your last major service ?
    A Major service is every 40,000kms.
    Requires.
    Leads, Plugs, Air/Fuel/Oil Filter, Oil Change at least.
    Also depending how long ago.
    Transmission service, Brake fluid change, Coolant change & Flush, Power steering Flush.
    & Checked all your gaskets, look for leaks of any sorts. Oil Locks & Door hinges, Tyre pressures/ Tread where. Lights, Coolant hoses, Brake pad/ disc wear, Suspension, signs of rust.
    That should give you a good starting point.
    VT II Berlina
    Aug 2009
    Hampton Park, VIC
    Last major service was a 200,000, so I'm thinking it's probably overdue.
    Also, it's been running a bit dodgy lately, spluttering at times, rough idle and it's cut out when cold a few times, both in drive and reverse. Could that be spark plugs, does it need a tuneup or something worse?
LinkBacks (?)
  1. 250k on a vt buying trouble?
    By andrew81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2009, 06:49 PM
  2. HSV 250k RED Speedo Dials
    By andyos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2008, 11:36 AM
  3. VT 250k dash Insert
    By Riggy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2008, 06:25 PM
  4. 80K Book Service - VTII Berlina Wagon 6cyl Auto
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2006, 09:08 PM
  5. Help with Service/explanations of inner workings [84 VK Berlina]
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2005, 08:29 PM
Tags for this Thread
