Hi all,
I'm a newbe to this site but not to forums in general.
My name is Barry but people call me Bazz.
My car just developed a real bad / loud ticking sound that's coming from around the harmonic balancer / pulley end of the 3.8 V6 ecotec engine. When you give it a rev it increases in speed then seams to quieten down.
Any thoughts???
Cheers Bazz
####ed idler pulley.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
Gidday mate,
Thanks for the reply, I'll sort it tomorrow.
Hard luck with the nature beating you guys are getting over there at the moment... chin up etc
Bazz
hey buddy let me know how it goes! i think i might have the same problem!
I have a similar sound coming from my motor but was told by a couple of people (1 a mechanic) suspect timing chain tensioner. Anyway I am going to replace them and see who was right. Might do the harmonic balancer while I am there. It has 224700 on it so would be near due anyhow.
Hi locolatino & graham7773,
Yeah just dropped mine off this morning to the mechanic, so hopefully it's not that bad ... mine's done 244000km so I guess some things are gonna wear out sooner or later.
Up Date.... It was the air con pump bearing...It's cheaper to get a second hand pump than overhaul the original. Still looking at $500 to install & refill air con!
Bazz
Oooo that sounds about right! my air con isnt 100% so theres a good chance it might be that! thanks alot man!! helped heapsss
