I changed the regulator and front drivers side door handle, re-connected the battery and everythings dead, no power, electrics and even the immobiliser lights not flashing. Any ideas?
Battery not connected correctly or bad connection, blown fuse or fusible link.
MY RIDE
everything was running fine before i started, battery should be fine but ill check it again , and i never had a prob diconnecting the battery before so i dont think its got to do with the radio code or wateva im puzzled its completly dead?
As previously said. Check all your fuses and main fusible links. You've most likely blown one.
Originally Posted by Reaper:
Originally Posted by Jecs:
ok thanks.
