Results 1 to 4 of 4
Thread: how to remove steering surround?
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    Default how to remove steering surround?
    i just brought myself a VT been driving it round.
    today i noticed the indicator was making the 'indicator flashing' noise but no indicators were active.
    i replaced the flasher can, but that did nothing.
    i also noticed small amounts of smoke comming from behind the steering wheel, so i reckon it'd be the indicator stalk causing my woes and i need to get the surround off the column so i can get in to change it out.
    1 question... how do i remove the steering column surround on a VT without removing the wheel?
    only other commodores ive worked on have been VN-VP-VR's which were easily removed by taking out screws, the VT's however look like they have some weird mount holding everything in place.
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
    Mar 2005
    Melb
    ok, i just figured it out care of this great diagram.
    1 screw - hidden behind the fusebox if its closed, then pry the surround apart.
    kudos to the original replier for providing it on this thread.
    looks like it is in the indicator stalk, cuz if i hit the hazard lights with the stalk in, the flasher can go's nuts, without it, the hazards work fine.
    (im hoping its the indicator stalk at least - will update when i get a new one)
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Lower the steering column. Remove the upper cover by pushing the lower cover slightly down in the direction of the steering shaft and then lift the upper cover and move towards the steering wheel.
    Remove the lower cover by removing the retaining screw and then push it towards the upper end of the steering column to release the cover from the 2 retaining hooks on the steering column.
    It sounds difficult but there is no other way to explain it.
    Edit: Looks like I'm a bit too late. Slow typer.
    MY RIDE
    VT
    Feb 2010
    Quote Originally Posted by adept View Post
    Thought I seen that pic somewhere
  1. How To Remove VY Seats/Stereo surround etc..
    By sweefu in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-07-2010, 11:01 AM
  2. How to remove head light switch from dash surround please
    By smokin_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2009, 05:05 PM
  3. remove rear vent surround in vx?
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2009, 11:21 AM
  4. how to remove automatic stick and surround
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2008, 12:18 PM
  5. Polished Steering Surround.
    By 308vkcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-10-2006, 08:59 PM
Tags for this Thread
