Results 1 to 4 of 4
Thread: Minimal Accessory Lights?
    VU S2
    Jan 2011
    Default Minimal Accessory Lights?
    Okay, so i'm having a problem with my VU's lighting for my accessories at night.
    The panel which has the demister, aircon etc is not lit up at night apart from only the demister which I find strange (why would one be working and not the rest, shouldn't they all fail?)
    Also, the emergency button isn't lit up either, so this whole section is in darkness, except the demister light.
    I checked the small 10a fuses this morning and they seem okay, am I missing something else?
    Phantom Black VT Executive
    Aug 2010
    It could be possible that you have just a shit load of blown bulbs, that would be the second thing to check after replacing the fuses.
    As for the hazard switch, it could be just a faulty connection, because i know that's the case on mine. The hazard switch also has a separate fuse i think, so check that.
    VU S2
    Jan 2011
    Quote Originally Posted by ZaRnOw View Post
    cheers mate.. i'll check the bulbs and what you've suggested tomorrow. they were all working only a week ago, so it's strange they would've gone at once but worth checking..
    Aug 2010
    Best of luck m8. If the bulbs are all not blown, then you will need to get the multimeter or test light out and find out why there is no power getting to the bulbs.
    Good luck
  1. Accessory wires!
    By seventhspine in forum Electrical Wiring / Questions
    Last Post: 17-12-2010, 09:49 AM
  2. For those into minimal/techno.....
    By roon_VR in forum Jokes/Humour
    Last Post: 20-01-2010, 09:59 AM
  3. dash and accessory lights
    By Honda_rider380 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2010, 03:35 PM
  4. Better performance with minimal visual and audible difference?
    By usernameguy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2008, 08:50 PM
  5. VZ accessory wiring
    By Dover1123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2006, 04:21 PM
