Results 1 to 3 of 3
Thread: throtle pedal issues
    lion_g is offline LionG
    VT Executive Series II 3.8/V6
    Jun 2009
    T'Ville
    Default throtle pedal issues
    hey guys got a vt commy executive...my problem is the pedal is locking every now and then when i plant it but my main issue is that the pedal can go in and out easy with slight pressure on it how ever when i push it in it does not rev almost like i have to push the pedal to 40% before any throtle is added to the engine..any ideas!!?
    thanks in advance for the help!
    VT Acclaim Wagon
    Oct 2008
    You need somebody to help here. Get the volunteer to sit in driver seat while you watch the throttle. If they push the pedal 1/4 down and you see no movement, I think it might be new throttle cable time. I also suggest that you use the VX cable. It it less prone to the problems the VT cable has. The main difference is the VX one is a lot shorter and is differently routed ie does not go around the strut tower and seems to be a better quality for some reason. There is also a chance that your throttle butterfly may be sticking, needing a clean.
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    throttle cable ..... when mine was stuffed it was half sticky like that , the throttle would increase with sharp jabs/jerks rather than increase smoothly... but if i took the cable off and pushed the able in and out it would feel free and smooth... it was only getting stuck when was hooked up and it had the pressure on it and bends..... the sticking that i could feel with my foot was real minor, but was alot worse on the throttle end....(wouldnt have been 40% thou before the rev's increase, mayb 10-20%, was just everything flexing till the sticky bit let go then i would get a whole lot of throttle at once)
    used to change back down a gear at 100 easier too ,(think was cause of the sharp jolts on the throttle from it sticking)
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
  1. Throtle Issue
    By witty92 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2010, 09:21 PM
  2. Throtle Body
    By ALOWVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2010, 09:09 PM
  3. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  4. Brake issues - pedal feels soft
    By dazamaz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-08-2008, 04:08 PM
  5. V8 Throtle Body
    By VRAddiction in forum Swap / Wanted to Buy / Trade
    Last Post: 14-06-2006, 04:40 PM
