Results 1 to 20 of 20
Thread: Car randomly died, then fans staying on after cars turned off...
    VT Calais
    Jan 2009
    Default Car randomly died, then fans staying on after cars turned off...
    Well ive had some major issues with this car, the head gasket went 5 months ago, then a month later i had an electrical issue, which made me replace 2 alternators 2 batteries, eventually was told it was the wiring harness.. i got the car back after holden had it for 2 months, rarely drive it as a have a work car,
    went down to the shop just then, on way home revs dropped a bit then 200m down the road engine died, pulled over, started the car drove 20m then it died again, the temp light came on and temp was sitting 3/4 of way up, managed to start the car and get home, then the fans stayed on after the car was off (fan relay?)
    any ideas? would the fan relay cause the car to drop out? im ####in stumped yet again
    VT Calais
    Jan 2009
    also since getting the car back, its not starting properly, takes a few chugs before it turns over, then sometimes turns over and stalls straight away,
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    Its ment to stay on if its way too hot.. Theres a certain temp it will switch on and stay on till cool's a bit..
    As for not starting after overheating i'd be a bit worry'd, 'may' have cooked it and done damage..
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    Sep 2009
    goldcoast
    4mins they should stay on with ignition off, if gets above 117 deg
    VT Calais
    Jan 2009
    it does start now, but really chugs before it gets going , was doing this before but not as bad? if thats any help
    Sep 2009
    goldcoast
    not sure on the chugging side of it...
    but if its overheating loosing water and running like a pig i'd be looking at the gaskets, LIM or head..
    VT Calais
    Jan 2009
    Quote Originally Posted by wana s' charge stock vt View Post
    it just had all the gaskets replaced not 5 months ago, water pump aswell, what are the chances of that happening again
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Faulty thermostat?
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    Sep 2009
    goldcoast
    Quote Originally Posted by Simsy23 View Post
    depends if the apprentice did all the work
    lol not too sure hey, ya can get a test done to see if ya have exhaust gases in ya water from cracked head, and a pressure test or something...its pretty quick and easy..
    VT Calais
    Jan 2009
    Quote Originally Posted by D3CID3R View Post
    Faulty thermostat?
    could that be causing the car to be struggling to start though?
    Sep 2009
    goldcoast
    na, it may have caused it to overheat thou...
    VT Acclaim Wagon
    Oct 2008
    I would be looking for another engine, before it dies completely. Were the heads recoe'd 5 months ago? Machined etc? Or just cleaned and replaced with new gaskets? Sounds like the second option to me. And your temp sensor seems not to be doing its job either. Genuine 3/4 temp is not enough to stall your car. I am agreeing with "wanna". You may have cooked it.
    Commodore M6
    Jul 2010
    East Coast
    had the same problem with the fans
    it's a faulty relay
    $10 fix but cost a $100 battery
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Starting problems could be CAS or ingntion coil. If it has weak or erratic spark then it will be rich A/F.
    muttley383
  15. #15
    VT Calais
    Jan 2009
    Quote Originally Posted by graham7773 View Post
    they were completely overhauled, new top set gasket, new spark plugs, new thermostat, new water pump..
    the engine is starting but its struggling to start now.. even more then before though
  16. #16
    VT Calais
    Jan 2009
    whats the best way to check if the gaskets gone again? with the radiator cap do i have to block the feed from the coolant resovior to check it?
  17. #17
    VT Calais
    Jan 2009
    ok so i left the car over night, just went to start it, started first time, drove it around the block, temp stuck on C, few minutes later finally moved off C and worked its way up to the red, checked the engine it didnt seem overly hot,
  18. #18
    Sep 2009
    goldcoast
    take it back to whoever did the heads and tell them... they should have the shit to test it to see if its leaking and where from......
    but i wouldnt let it get too hot thou or ya will do bad damage.. 3/4 is tooooo hot,
    also ive had a near new thermostat that has been dodgy so still may be that
  19. #19
    VT Acclaim Wagon
    Oct 2008
    Just a thought, are you running decent quality coolant in your cooling system? As you probably know, water boils at 100c and the pressure cap takes that up to about 108c. Your cooling system is designed to run as hot as 130c and if the coolant is not up to the correct (50%) mix the system will just boil the water out of the overflow bottle and suck air back in, same as if you had a blown head gasket. There a few good anti freeze/anti boil coolants but for price and longevity, Nulon is one of the best. It takes your boiling point to 132c @ 50% mix with soft or demineralised water. Using straight tap water is not recommended as it reduces the protective qualities of any coolant.
  20. #20
    Commodore M6
    Jul 2010
    East Coast
    the dudes should have a device that bolts to the radiator cap neck that looks like a big thermomter that will show if it's got a blown HG
  1. my other cars/past and muched loved cars
    By VS_Commy in forum Miscellaneous
    Last Post: 17-09-2010, 07:20 PM
  2. car stalling on me randomly
    By rusty91 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2010, 11:08 PM
  3. Alarm goes off randomly?
    By NORTI in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-03-2010, 02:57 AM
  4. Replies: 11
    Last Post: 27-02-2009, 11:53 PM
  5. VT S Pack engine fans keep running after car is turned off.
    By Cashy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 08:24 PM
