Results 1 to 5 of 5
Thread: vt power window wiring diagram
    v8 vn berlina-vt series 2 wagon
    Jul 2010
    newcastle
    Default vt power window wiring diagram
    hey i have vt i want to put power windows in ,i know the body control module is different but was thinking about not running through that doe anyone have a wiring diagram??????cheers adrian
    VX Executive
    Nov 2008
    Bolton point Newcastle
    you should have all the wiring to do it, all I did when I installed power windows in my VX was to change the door looms and cut the wires from the drivers door and run them to master switch to by-pass the BCM hopes this helps!!!
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I've posted this before, a search should have found it. Open attachment in a new window for a bigger view.
    Attached Thumbnails Attached Thumbnails vt power window wiring diagram-wiring-windows-doors-mirors.jpg
    MY RIDE
    Jul 2010
    newcastle
    ok my bcm is 313 mid level can i just wire it into this or do i need holden to do something to tell it has power windows???also are sedan rear window power regulators the same as wagon?????????cheers adrian
    VY Crewman
    Nov 2011
    Redcliffe
    Does anybody know if this diagram would be the same as a series 2 VY Crewman, and if not where I could find a diagram to suit?
    I have tried searching and this is the best I have found so far, please help.
    Cheers Brian
LinkBacks (?)
  1. 15-02-2012, 11:56 AM
  2. 05-12-2011, 09:14 PM
  3. 30-11-2011, 04:05 PM
  4. 09-09-2011, 04:50 PM
  5. 08-09-2011, 09:27 AM
  6. 29-05-2011, 10:59 AM
  7. 02-05-2011, 08:55 PM
  8. 12-04-2011, 02:21 PM
  9. 15-03-2011, 06:43 PM
  10. 15-03-2011, 03:29 PM
  11. 23-02-2011, 07:46 PM
  12. 17-02-2011, 02:57 PM
  13. 16-02-2011, 11:50 AM
  1. VX Auto Window Wiring Diagram.
    By StealthX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2009, 08:22 PM
  2. VN power window wiring diagram
    By combatantsomeone in forum Electrical Wiring / Questions
    Last Post: 09-02-2009, 07:01 PM
  3. power window wiring diagram
    By sumsle in forum Electrical Wiring / Questions
    Last Post: 21-10-2008, 05:31 PM
  4. Wiring diagram for power window switches
    By veeque92 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-08-2006, 07:46 PM
  5. Wiring diagram / help power window switches.
    By veeque92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2006, 06:22 PM
