Hi all, have tryed the search function and just after more advice
Recently purchased VX acclaim wagon, horn and s/w controls not working, took fuse out to check saw it was OK so was replaced, both started working. Next time I went to drive car not working again. While replacing manifold gasket, battery was disconnected overnight, on reconnection started to work again, but as before only until next drive ?????
Could this be a faulty clock spring???? (no light on dash) or possibly something else ????(airbag module) Is there testing procedure for these things?
I have a Ellery workshop manual which I can"t find anything about this
Any help would be much appreciated
Clock spring was the first thing that came to mind after reading your title, but I can't be sure about that.
MY RIDE
Hey guys,
I done a search and found this thread and was wondering if anyone else has had this problem.
One of my cousins has given me their car for the weekend to replace the brakes, service the transmission, etc. It's a 2001 VX Executive and the steering wheel controls for the radio stop working intermittently. They told me about the problem a while ago but I never found the problem, so I was wondering if anyone else has had this happen to them, and knows how to fix it?
I can't honestly say if the horn is working or not as I haven't tried it.
Cheers,
Ben.
Originally Posted by Jasper44
Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
Hey guys, horn works but steering wheel controls don't. Airbag light is NOT on, so I don't think its the clock spring. Any thoughts?
Oh ok, I just went out and tested all the fuses and they were all ok. I'll just tell them that if they want them working again they will probably have to get the clock spring replaced. I probably wont do that myself. I took my VS Berlina to a Holden dealer to have the clock spring replaced as I didn't want to risk setting off the airbag.
I had the same problem with my vu. Steering wheel controls didn't work, but the horn did work and the airbag light wasn't on. Brought another clock spring from wrecker and all good. Just make sure the one you buy hasn't had the airbag deployed or it wont work.
