Results 1 to 7 of 7
Thread: wider tyres
    VT Acclaim Wagon
    Oct 2008
    Default wider tyres
    is there any advantage in putting wider wheels and tyres on the rear end only only? Also, how do you strip old paint off alloy wheels
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    If the car is stock as a rock and low on power, like mine for example, then there
    is no point. But if you've got more power then it obviously gives you more contact
    with the road and therefore more grip.
    As for the paint thing, no idea man, paint stripper???
    None of us are as cruel as All of us. - Anonymous
    02' VXii Exec 9C1
    Aug 2009
    my guess for the paint would be thinners or my personal favorite...hydrochloric acid
    First Car: 01' VX S
    Second Car: 02' VXii Exec 9C1
    ve ss-v 2008 ute
    Aug 2010
    perth
    Not to mention if you have wider tyres on the rear and there directional you wont be able to rotate them for even ware on the tread
    THERE IS NO SUBSTITUTE FOR RAW HORSEPOWER !!
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Paint stripper should be fine, read the label to make sure. Hydrochloric acid will eat metal and probably leave the paint.
    MY RIDE
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Wont make much difference for traction. Theres only a certain amount of tread on the road with IRS anyway and it aint much lol.
    If you want more traction go and get a 4 point camber correction kit installed, i had mine done years ago and what a difference. Worth every cent and is alot better for tyre wear.
    VT Acclaim Wagon
    Oct 2008
    IBLOWN, thanks for your camber idea. I was thinking about a VY or VZ rear cradle with my diff mounted in it. Only problem is they are still a bit hard to find at a reasonable price. I have an Acclaim wagon. Still trying to find out if the 2003 Statesman cradle will work as I know where there is one available.
    accent, I will try stripper on the back of a wheel. Hydrochloric would get through an alloy wheel in about 45 seconds I guess, unless it was watered down to about 10%.
  1. [SA] Wanted - 215/60/16 tyres x 2 or 17" rims w/good tyres
    By Textavs in forum Swap / Wanted to Buy / Trade
    Last Post: 01-02-2011, 05:45 PM
  2. WTB: Cheap set of 18 or 19 inch rims - tyres or no tyres...
    By Timzo in forum Swap / Wanted to Buy / Trade
    Last Post: 07-04-2008, 10:56 PM
  3. wider footrest for auto?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2005, 10:45 AM
  4. wider rims mods
    By hinterland in forum General
    Last Post: 24-11-2005, 08:00 PM
