can i get this knob and boot to fit my vt 6spd?
VY-VZ 6 SPEED LEATHER SHIFTER
Real cars don't power the front wheels, they lift them
i have this one
it's good
i'm pretty sure you should have the monaro short shifter to fit it though
If you remove the plastic base around the leather, and secure the leather to the centre console someother way then yes.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
