Results 1 to 10 of 10
Thread: car not remembering timer for headlights
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Default car not remembering timer for headlights
    hi guys recently my vt calais has been stuffing up, i have it set so when i leave the car the headlights stay on for 30 seconds then turn off automatically, but in recent weeks, it seems to keep resetting itself, meaning as soon as i open door they turn off, any ideas why this would be, i keep resetting it back to 30 seconds, it lasts a few starts but normally by end of day or most the next day its reset again, any help would be great thanks guys
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    why do you want them to stay on for 30 sec any way?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by MR_VX View Post
    helps for where i park so i can see to where i have to walk, plus its a calais feature so not really a matter of whether i want it or not, its a feature so it should work
    VT Calais
    Mar 2009
    SA - Victor Harbor
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by lufkin View Post
    Id try disconnecting the battery for an hour or so,this will reset the BCM (Body Control Module) which controls the timer for the headlights etc.Hopefully when its reset,you can then set it back to 30 seconds delay,and it will work ok again.If that does nothing,holden can do a diagnostic check on the BCM with a tech 2 scantool ,this should show up any problems it may have.If still no different,then Id look at replacing the BCM.If you decide to get a second hand BCM fitted,you will also need to have the matching ignition keyfob from the same car the BCM comes from,and they will need to come from another calais.You just have to swap the plastic key fob over to your ignition key,theres 2 screws that hold it to the metal part.The BCM and the ignition keyfob have to have matching security codes for the immobiliser.Otherwise the immobiliser will not disarm to allow the car to start..You will also need to get the BCM "linked" to the ECU (Electronic Control Unit),you will need to see holden who do this using a tech 2 scantool.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    fair call then
    VT Calais
    Mar 2009
    SA - Victor Harbor
    vs commodore
    Oct 2009
    Tamworth NSW
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Ive got the same problem after a BCM swap. My old BCM would switch them off when the door was opened. The new one doesn't switch them off at all, it's a HI series BCM with a newer part number. Everything else runs fine. I tried setting the time for off but it wouldn't finish the set process and just turned off all the cluster lighting and beeped. :S
  1. first timer
    By ssvfanatic in forum The Pub
    Last Post: 11-01-2010, 04:16 PM
  2. cant get key out of terrano with T-timer on
    By delcowizzid in forum The Pub
    Last Post: 07-08-2008, 07:32 PM
  3. old timer!!
    By cxcxcxvcvcvc in forum Jokes/Humour
    Last Post: 21-09-2007, 07:25 PM
  4. I was just remembering...
    By PIMPIN in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-10-2004, 06:00 PM
  5. First Timer
    By tommi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2003, 10:01 PM
